trick behind the boom box
Old 4th January 2009, 07:08 AM   #11
cbdb is offline cbdb  Canada
they usualy mix on a number of speakers and check it at different levels, and the good mixers can make it sound good on any speaker at any level, the problem is producers that want it to jump out of your radio.. sorry way of topic and time to stop.
Old 7th January 2009, 01:53 PM   #12
ravslanka is offline ravslanka  India
Originally posted by breez
Punchy and heavy bass is around 100 Hz. No trickery needed other than an equalizer circuit to boost 80-160 Hz band or perhaps a high Q reflex tuning around 100 Hz.
hi breeze,
i have googled for boostng a particular frequency band but i didnt found anything any circuit would be appreciated
thanks in advance
Old 7th January 2009, 05:26 PM   #13
MisterTwister is offline MisterTwister  Tibet
just use "winisd pro" to tune speaker box with bump in 100hz.
those plastic boomboxes have very fatiguing sound.
they may impress with their sound at first, but you can't listen to them for prolonged time.
Old 17th January 2009, 10:46 PM   #14
brig001 is offline brig001  United Kingdom
A circuit was published in Everyday Electronics circa 25 years ago, IIRC (which is doubtful at my age...).
They used a trick to fool the brain into thinking the bass note was there when it wasn't. They added second and third harmonic distortion, then removed the fundamental. The brain heard the second and third and filled the fundamental back in for you.
So: 50Hz becomes 100Hz and 150Hz, the only time you would hear those frequencies together would be when the original 50Hz was present.
Now I have no idea whether they use this technique these days or not...
trick behind the boom boxHide this!Advertise here!
Tom's portable boom box! ScottG Subwoofers 9 10th June 2008 09:18 PM
mini boom box M3G4 Class D 3 18th January 2007 12:51 PM
best boom for the buck? peace brainerd Subwoofers 10 15th December 2005 09:56 PM
boom box formulas.. nbcd Multi-Way 0 22nd February 2005 01:50 PM
Kenwood KAC 820 Amp went Boom! sidskiba Car Audio 8 3rd December 2004 05:58 AM
