Old 15th December 2008, 06:03 PM   #1
Default Fixing a cracked subwoofer cone
Looking for any tips or advice to fixed a cracked cone.
The cone is COC (cyclic olefin copolymer).
Crack starts at the surround and continues about halfway under the dust cap.
I've read CA glues should not be used on polys, but nothing definitive about the COC plastic.
To preserve cosmetics as best as I can, I was thinking covering the crack on the face of the cone with tape, and using some type of CA glue on the back side, letting it seep into the crack.
Any better ideas?
And what about behind the dust cap, should I remove the cap or will gluing on the back side be sufficient?
Old 16th December 2008, 06:24 PM   #2
Default Well maybe
Hi, your method sounds like the best idea, no experience of the COC, I'd ask a few adhesive manufacturers as it could be a tricky one, I'm just an electronics guy but I get the impression from searches that its similar to Polypropylene which along with PTFE does not 'stick' that well. Try these people and then 3M
http://www.masterbond.com/
Good luck! RC
Fixing Subwoofer wire leads audiobahnkid592 Car Audio 9 23rd December 2010 04:19 AM
Fixing possible broken subwoofer Sepultura Subwoofers 11 25th August 2004 07:24 AM
Fixing/upgrading velodyne subwoofer thomas997 Everything Else 1 10th April 2004 05:49 AM
Need Help Fixing Sunfire True Signature Subwoofer Creelove Parts 0 2nd March 2004 08:05 PM
Need Help/Schematic Fixing Sunfire Signature Subwoofer Amplifier Creelove Subwoofers 1 2nd March 2004 08:01 PM
Page generated in 0.06993 seconds (68.80% PHP - 31.20% MySQL) with 10 queries
