Old 14th December 2008, 06:54 PM   #1
HTRookie's Avatar
Default Passive Radiator Excursion
I recently completed a dual passive radiator sub, closely based on Adrian Mack's design, using a 12" Peerless XLS driver with two 12" Peerless passive radiators. The PR's are the 425 gram versions, with an additional 275 gms. of weight added. In use, the active driver seems to move noticeably more than the passive cones. Is this normal, or have I done something wrong?
Thanks for your help!
HTR
Old 14th December 2008, 07:15 PM   #2
Daveis is offline Daveis  United States
I also built a dual 12" sub using TC sounds drivers, but using the same Peerless XLS passive radiators.
I'd say that could be normal depending on what material you are playing.
If possible put a sine wave sweep tone through it, but remember your ears get less sensitive as the frequencies get very low. So it could sound like it isn't flat but it really is. Also, your room can make 10-20db peaks/dips in frequency response.
Soundeasy or Praxis are some software that might help but they aren't cheap.
The problem I experienced was a flapping sound coming from one of the passive radiators.
If your bass is ultra weak then possibly your box volume needs to be reduced.
Old 14th December 2008, 09:57 PM   #3
Speakerholic
Cal Weldon's Avatar
Hello Bruce, nice to hear of your latest spawn. Modesty is definitely not in order, we'd like to see a pic or two please.
Assuming you've already done a pressure check and different room placements, I think you know PR's are a favourite of mine and here's some things I've thought about translated to "after beer speak".
The drones are reactive so the movement is likely to be 50% if you have matched mass and cone areas, compliance and perfectly sealed cabinets.
A heavier drone has a hard time moving so you lose the higher frequencies.
700 grams means you are reinforcing the really low end.
There's a lot of high excursion info in the 70 - 125 hz area so the big heavy passives can't just can't keep up while the woofer appears to be merrily flapping away. If you are lacking warmth, remove the extra weight and listen again. What shows up on a graph doesn't always make your ears happy.
How are things? long time no speak.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 15th December 2008, 10:10 PM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
If you post the parameters of both woofers and passives, and the box size you use, someone could model it and see how simulations match up with your reality.
At very low frequencies, it will be as Cal says, but the passive does more than just match the woofer excursion in the area around tuning. Above tuning (more than say 2-3x tuning) the passive won't move much at all.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 16th December 2008, 01:00 AM   #5
HTRookie's Avatar
Default Subwoofer Photos & Design Info
Hello again,
Thanks for the information. I have attached a photo of my sub. It is ~50 litres internal volume, constructed from dual layers of 3/4" MDF, with a vertical "I beam" centre brace laminated froom hardwood and Baltic Birch plywood. West System epoxy is used along with polyurethane adhesive. The amplifier is an Adire ADA1200 (gain turned down!). The steel circles you see on the cabinet are used to secure the grille frames, which have rare-earth magnets epoxied in them.
I know it will not match the bigger 15" subs out there, but I hope it will do a pretty good job.
I appreciate your assistance!
HTR
Old 16th December 2008, 01:02 AM   #6
HTRookie's Avatar
Default Subwoofer pics
Here are the photos, sorry :<(.....
Old 16th December 2008, 01:49 AM   #7
HTRookie's Avatar
Peerless 830500 12" XLS Driver
Electrical Data
Nominal impedance
Zn
8
ohm
Minimum impedance
Zmin
4.7
ohm
Maximum impedance
Zo
64.2
ohm
DC resistance
Re
3.5
ohm
Voice coil inductance
Le
4.2
mH
Capacitor in series with x ohm
Cc
38
uF
T-S Parameters
Resonance Frequency
fs
18.1
Hz
Mechanical Q factor
Qms
3.7
Electrical Q factor
Qes
0.21
Total Q factor
Qts
0.2
Force factor
Bl
17.6
Tm
Mechanical resistance
Rms
5.12
Kg/s
Moving mass
Mms
166.3
g
Suspension compliance
Cms
0.46
mm/N
Effective cone diameter
D
24.4
cm
Effective piston area
Sd
466
cm2
Equivalent volume
Vas
139.2
ltrs
Sensitivity (2.83V/1m)
90.6
dB
Ratio BL/(Re)
90
Ratio fs/Qts
F
Power handling
100h RMS noise test (IEC)
W
Long-term Max Power (IEC 18.3)
W
Max linear SPL (rms) @ power
dB/W
Short Term Max power (IEC 18.2)
W
Voice Coil and Magnet Parameters
Voice coil diameter
51
mm
Voice coil height
33
mm
Voice coil layers
4
Height of the gap
8
mm
Linear excursion +/-
mm
Max mech. excursion +/-
mm
Flux density of gap
1.04
mWb
Total useful flux
2.5
mWb
Diameter of magnet
147
mm
Height of magnet
35
mm
Weight of magnet
2.42
Kg
______________________________________
Peerless 830548 12" Passive Radiator (2 used)
TS Parameters
Resonance Frequency fs 10.4 Hz
Mechanical Q factor QMS 15.2
Mechanical Resistance Rms 1.8 Kg/s
Moving Mass Mms 425 g
Suspension Compliance Cms 0.55 mm/N
Effective Piston Area sd 466 cm^2
Equivalent Volume Vas 169.6 ltrs
Old 17th December 2008, 12:34 AM   #8
Ron E's Avatar
model attached. I didn't enter Qp correctly but the effect should be small. This is with the full input of a 200W/8 ohm amp or a 400W/ 4ohm amp. You are just reaching driver excursion capability above tuning, but below tuning you are in the danger zone. You might want to put a 20Hz highpass if your amp doesn't have one. It depends on how much power you have on tap. - to reduce excursion by half at any frequency, you must reduce power by 4 times.
Note that except around tuning, the PR excursion is less than the woofer - a lot less.
edit - nice looking sub, BTW.
Old 17th December 2008, 02:09 AM   #9
HTRookie's Avatar
Default Peerless Subwoofer Feedback
Thanks Ron for your efforts. The box is sealed, 54 litres gross, approx. 50 litres net internal volume. I am using the Adire ADA1200- 1200 watt (4 Ohm) plate amp. I am reviewing the manual as the amp does have a number of filter features on it. As Cal said, perhaps I have too much weight on the passive radiators- did your modelling indicate that?
I glued the weights on using a special elastomeric adhesive, but I could get them off if need be with some effort. I just followed Adrian Mack's design, as it seemed a sound one and was well thought of in the DIY ranks.
Thanks to all for your feedback
HTR
Old 17th December 2008, 07:34 AM   #10
Over half a cycle you have one active cone moving in therefore the two remaining passive cones will move out half as much. It's simple piston area maths imho
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
XLS passive past excursion Kram Subwoofers 21 29th November 2007 05:59 PM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
Page generated in 0.11937 seconds (81.22% PHP - 18.78% MySQL) with 11 queries
Copyright 1999-2012 diyAudio
