Multiple Small Subs - Geddes Approach Multiple Small Subs - Geddes Approach - Page 101 - diyAudio
Old 17th April 2009, 03:10 PM   #1001
gedlee is offline gedlee  United States
gedlee's Avatar
Originally posted by markus76
... you still have a problem if there's bass on only one of the front channels. Under that circumstances 2 of the 3 front channels won't act as low frequency sources anymore. We both don't know if this is a real problem because there simply is no data.
Best, Markus
Worst case its a hypothetical problem with no data to support your claim and best case it isn't a problem at all. So what if there is bass on only one of the channels, I don't see how that affects anything at all. Two of the three front channels don't have bass, but there wasn't any in the mix on those channels anyways - what's the problem? I don't get it.
Earl Geddes Gedlee Website
Old 17th April 2009, 03:31 PM   #1002
markus76 is offline markus76  Germany
Banned
There's also no data to support the best case, right? And as long as there's no such data there'll always be a potential flaw in your solution.
The use of multiple subs makes only sense if ALL low frequency sources emit the SAME signal at ALL times. I really don't understand why you would want to challenge that.
Best, Markus
Old 17th April 2009, 04:00 PM   #1003
randybes is offline randybes  United States
Best, Markus
Isn't this all really just going to come down to "the proof is in the pudding" so to speak. I suggest Markus develop his ideas or use the JBL box when it comes out, and Earl can do his thing and then the market will determine.
Old 17th April 2009, 04:04 PM   #1004
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
pjpoes,
I would love to take a closer look at multichannel signals but haven't found an easy way to do it yet.
I own a DCX and use it in my 2 channel setup now for years.
The DCX has basically the same problem as the DEQ has. It's built for PA and not for home use. The max. input level is 22dBu which is much more than consumer electronics can deliver. You will "loose bits". If you're running the DCX behind the volume control then you'll further loose bits. But there are 24bits@96kHz so this might not be a problem at all.
The hiss was probably not a problem with the unit but with unbalanced cabling. That's why I run my whole setup balanced. Hiss can also be caused by a hardware bug of the DCX. It becomes audible only when using the digital in.
Best, Markus
Markus,
I am using a computer as a source, with a sound card that has balanced outputs. It's an Echo Audio MIA, which is considered a "pro" sound card.
Do you think it would be a good match for the Behringer gear?
Here's the problem that I am experiencing with my current set up:
I am using a Y-Cable to split the signal, and one side is going to a sub amp, the other is going to a second amp for the Summas.
When I run the Summas alone, it's as clear as a bell.
When I run both the subs and the Summas, the subs have a hum at about 60hz.
My guess is that a ground loop is being introduced, and it's introducing the hum into the subs?
Also, do you use amplifiers with balanced inputs?
Old 17th April 2009, 04:24 PM   #1005
gedlee's Avatar
Best, Markus
Correct, there is no data either way, so the best we have is logic and analysis and neither favors you claims.
Your last sentence is not one that I agree with, which is perhaps, the issue. I see no reason to assume that the signals need to be identical. In fact, I have said many times that, in theory, the signals to each sub should be decorrelated, meaning NOT identical.
You seem to be digging in your heals and grabbing at straws just to "be right".
Old 17th April 2009, 04:26 PM   #1006
gedlee's Avatar
Ground loops to subs can be a real pain as ground loops are always hard to issolate. I usually end up cutting off the ground lug on the power plug. This seems to work most times. A little risky, but not that much.
Old 17th April 2009, 04:39 PM   #1007
Banned
Patrick,
the devices have to use the same ground if you're using a Y-cable.
Never ever cut off the ground lug! This is highly dangerous and even forbidden in some countries, e.g. Germany.
Best, Markus
Old 17th April 2009, 04:44 PM   #1008
I have found these to work exceedingly well for hum
http://www.zzounds.com/item--EBTHUMX
Old 17th April 2009, 04:47 PM   #1009
Banned
Plugging all devices into one outlet is $70 cheaper.
Best, Markus
Old 17th April 2009, 05:14 PM   #1010
gedlee's Avatar
This isn't always possible and not always effective. Cutting the ground lug is not such a big deal, because the equipment is still grounded, just not through that lug. Its grounded through the signal wire shield. If a short to ground occurs it will conduct the current through the signal wires and then to ground, but this should still blow the fuse before any damage is done.
Multiple Small Subs - Geddes ApproachHide this!Advertise here!
Copyright ©1999-2017 diyAudio
