#651 |
Markus
The modal density at 300 Hz is enormous. Modes are not an issue. |
#652 |
a) Depends on the room size, b) I said "up to" and c) don't forget about boundary effects.
#653 | |
John and Earl, all true. I was speaking only of the 0th mode though, not the total soundfield. i suppose that is a dangerous, and probably not useful thing to try to do. |
#654 | |
I am a little bit confused with the term 0th mode. I should not have use it myself Is this phenomenon true for any frequency below the lowest mode the room "supports" ? I mean, in a small room if the lowest mode is at 40Hz then nothing can be heard under that frequency, only felt, and then only with a sealed sub in a sealed room? |
#655 | |
This is darn near true and basically true for all "Practical" purposes. If the source is not a monopole then you cannot get sound below the first mode. If it is a monopole then the amount of sound will be directly dependent on how much leakage the space has - and the source strength or course. |
#656 | |
/Peter |
#657 | |
Hear the real thing! |
#658 | |
Were these instructions specifically to adding a cld layer of drywall resting on a rc1 channels mounted to existing drywalled wall of a room? Please excuse my ignorance as I have no construction knowledge, but what is the "joist"? I wikipedia'd this and it said it was something that is in regard to the ceiling/roof. So where is the fiberglass supposed to go? Could you please describe in very simple terms? I didn't think there would be any area to fill with fiberglass if the room was already built. Unless its between the new layer of drywall and the old layer? As an alternative to the liquid nails, I was looking at Green Glue. Mainly for comparison on cost and VOC. I found that the Green Glue company site has posted some comparisons for CLD constructions versus other methods. I want to point out that they specifically recommend AGAINST implementing a rc1 channel over an existing wall when trying to target low frequency absorbtion. http://www.greengluecompany.com/upgr...stingWalls.php More direct, look at the bottom of this link for conclusion http://www.greengluecompany.com/unde...TripleLeaf.php -Tony |
#659 | |
http://downloads.bbc.co.uk/rd/pubs/reports/1995-06.pdf Best, Markus |
#660 | |
Tony Yes, I was confusing. They are studs not joists. And if there is already a wall there then the studs aren't available to put in fiberglass. But lets keep one very important thing in mind. I am talking about LF absorption NOT sound isolation. All the articles above are dealing with sound issolation and absorption and issolation are not the same things. A far as hanging RC-1 on an existing wall I think that Green Glue is oversimplifying and overstating the situation. They are basically correct in most of what they say, except that there is no way that RC-1 would be worse, just not as good as striping down the wall to the studs and putting it on those - FOR SOUND ISSOLATION! BUT, I would suggest that the RC-1 on the existing wall would act as a very good sound absorber, even if it wasn't the best sound isolator. The situation is very complex and to talk details you have to understand the details. I don't agree with Grenn Glues comment to avoid using RC-1 directly on a wall as a really BAD thing. That is just not true. There might be better ways to do, but they are NOT as easy to do. Striping down a wall is a pain, just adding a layer with RC-1 is not hard at all. |
| Page generated in 0.13596 seconds (83.10% PHP - 16.90% MySQL) with 11 queries |
