#441 | |
Maybe more subs would deal with it? Placed relatively close to the walls that likely are about 5-6 meter apart? /Peter |
#442 | |
Consider the set of all linear, time-invariant, causal, and stable systems. The minimum phase systems are the invertible members of this set. To be clear, "invertible" means has an inverse in this set. In terms of the properties of the system, a LTI system is minimum phase if and only if it is causal and stable and has a causal and stable inverse. The point is that what a minimum phase system does to the signal is reversible by a realizable (LTI, causal, stable) filter. Here are a couple counterexample to your assertion: - an allpass filter is causal and stable but does not have a causal inverse - a highpass filter is causal and stable but does not have a stable inverse (pole at 0) |
#443 | |
Markus It turns out the the lowest mode of any room is independent of shape and depends only on the floor plan (or largest surface actually if the room is very tall). Thus calculate the lowest mode for a rectangle of the same floor space and you know what the frequency will be for any shape. The mode shape differs of course, but not the frequency. An interest result from my thesis, but it can also be proven in other ways, like the Rayleigh Coefficient. |
#444 | |
#445 | |
Thanks for picking up my error.
John k.... Music and Design NaO Dipole Loudspeakers. |
#446 | ||||
#447 | ||
Many thanks, Paolo |
#448 | ||
Because I'm not a structural engineer and I can not assume that the room structure and other damping behaves linearly. Most likely for audio the assumtion of the room being LTI is a good one. Quote:
#449 | |
Most homes where I live have framed drywall structures over solid concrete foundations. Those aren't too bad because the walls and ceiling are lossy enough to provide some damping. There are a few though that have hardwood floors over a crawlspace, and in those, the crawlspace forms an acoustic chamber. So there are actually two resonant spaces that are tightly coupled, one the room and the other, the crawlspace. Those are tough to deal with. There are things you can do to modify the resonance and damp the adjacent space, but I've never really been satisfied with any listening room that has a hardwood floor over a crawlspace. |
#450 | |
I appreciate a lot your answers, now I have much more clear ideas in my head. This forum is really a great place to learn! Cheers, Paolo |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Page generated in 0.16503 seconds (84.67% PHP - 15.33% MySQL) with 11 queries |
