Old 18th December 2010, 02:28 AM   #1361
AllenB is offline AllenB  Australia
I'm trying to reason how marginal is the difference between setting up by ear and using measurements so I can gauge how hard to try. I'm also curious about variable phase.
If I swap my corner sub and the one between the mains, I notice a sizeable difference either measured individually and together. They are different units but they have an almost identical response (SPL) and sensitivity. Each has nothing more than a 2nd order electrical low pass filter. The only difference, I guess, could be found in the phase plots.
My first concern is how much it matters which one I use in each location?
Old 18th December 2010, 07:58 AM   #1362
MaVo is offline MaVo  Germany
I would allways do measurements, as what sounds good after a short listening doesnt necessarily sound as well after a longer time. And how much does the location matter? Well, you can see that with a measurement
You can get a measurement mic (behringer for example) and a usb connection with phantom power for relatively low money, compared to the amount of use they have.
Old 18th December 2010, 09:12 AM   #1363
Thanks MaVo, I get much better results with my Behringer than with my previous mike. It's just that when I read the tutorials on how to do this it looks like you could do it without signal processing or all pass filtering. Now I wonder if it is necessary to do this.
Old 18th December 2010, 05:29 PM   #1364
gedlee is offline gedlee  United States
I would not expect much difference in your swap, but if you measure a difference then so be it. Choose the one that gives the best results. There is not much more to say.
Old 18th December 2010, 07:38 PM   #1365
Hi Earl
Audyssey now does multiple subs (2) too. Would like to hear your opinion on their optimization approach. You probably followed Chris Kyriakakis papers over the years.
Best, Markus
Old 18th December 2010, 10:02 PM   #1366
If you want to skip allpass filters and just deal with a mono sub signal, try the harman approach (google "harman white paper" for the site).
Old 18th December 2010, 10:15 PM   #1367
MaVo, you obviously didn't follow this thread from the start, I did.
Old 19th December 2010, 01:55 AM   #1368
Originally Posted by markus76 View Post
Hi Earl
Best, Markus
No I have not read any papers by Chris. I only read JAES and then not very much. Its been a very long time since I've read anything that I didn't already know. In fact my last two publications in JAES were letters about papers that had no references at all to prior art. They were both completely described previously. At any rate I have no idea what Audyssey does, so I can't comment (but you know my opinion on the rest of the Audyssey technology, along with all the other "magic" electronic boxes. I would basically put them all in the same place ...)
Old 19th December 2010, 10:15 AM   #1369
S. Bharitkar and C. Kyriakakis, “Robustness of Spatial Average Equalization: A Statistical Reverberation Model Approach”, Journal of the Acoustical Society of America, 116(6), 3491-3497, (2004).
There're also some AES convention papers.
Old 21st December 2010, 08:35 AM   #1370
So what?
My advice was just fine or do you really want to say Toole is wrong and his concepts dont work?
To quote someone famous who happens to also post here: "Markus, you are just too extreme for me at times."
You should think about your obsessive behaviour, it is unhealthy.
Page generated in 0.11662 seconds (80.44% PHP - 19.56% MySQL) with 11 queries
