#1211 | |
Yes, this is a design difficulty. The sag from the weight will be fixed by the weight / area which has to be correct for the resonant frequency to be right. Some sag of the panel will be unavoidable. You might be able to use standoffs, but they will stiffen the panel and reduce its effectiveness. The best thing would be to design for the sag, which should be predictable and build it so that when hung it sags to the right location. Getting the stiffness of the foam should not be a big problem. |
#1212 | |
Regarding panel area: How about ceiling panels? Usually that surface is available to a greater extent that walls in a room. Sheldon |
#1213 | |
#1214 | ||
![]() Quote:
I prefer this: The decay around the resonance frequency becomes dominant above the decay at other frequencies. I think, this comes next to the facts and is also understandable by non-PhDs (so by me, I am only a bloody graduated engineer, nothing that could compare to a real PhD (also, I am awfully drunk at the moment, but that was the purpose of this evening). Bye Baseballbat |
#1215 | |
unfortunately the ceiling isn't available in mine, but maybe in others. I have unusual shaped vaulted ceilings with multiple recessed lights and two ceilings fans. It leaves very little ceiling space to mount a bass absorber, and they would have to hang at a strange angle relative to the ceiling. It's probably a great options for others, all the better if you have suspended ceilings to hide them in, but I think walls will have to be my option. I got a price on some perforated metal, I'm going a different route. a 6" wide strip of perforated metal rolled for cheaper packaging, with enough to do 1 trap, was 130 dollars. Then a steel front panel was another 120 dollars. I'm going to have to look for surplus materials or get more creative. Drywall's cheap, maybe I should try that instead. |
#1216 |
I plan to just stick with the drywall, when the time comes. Nothing too exotic needed.
#1217 |
Its really hard to beat drywall.
#1218 | |
Hey Markus - all these Germans are going to give you a bad reputation! |
#1219 | |
#1220 | |
Earl,
I put some salt in my post and you only tasted that flavor. Why not lick on the sugar? Quote:
| Page generated in 0.12624 seconds (82.33% PHP - 17.67% MySQL) with 11 queries |
