#1041 | |
The idea of overlap seems counterintuative. I would expect that each additional source in the overlap region would add to the perceived volume in that region. If there is an overlap between 80-120Hz, I would expect to see a hump in that area in any frequency response measurement. What am I missing? Thank you for taking the time to post here and on other forums. This approach is ideal for those of us who have neither the money nor the space for the large powerful subs that are so popular today. |
#1042 | |
Sheldon |
#1043 |
Sheldon is basically correct. There is no bump because its all taken into consideration. What people just don't seem to understand is that below about 200 Hz the room dominates everything. Concepts on paper just don't apply. You don't know what the HP of a main is just because you set it at 80 Hz. or what the LP of a sub is, or where its f3 is just because your tune it "thus and so". That stuff is all irrelavent for the most part. But if you place the subs and mains in the room and measure them in-situ then you do know precisely how they work "in the room!" You can then optimize the setup for multiple seats and multiple subs to get the smoothest reponse obtainable in that room, with those subs and mains.
#1044 | |
Account Disabled
What is written above would not stand a further analysis. A resonator is a resonator irregardless it is realized as a mechanic or electronic system. The clue here is that decay is a change of the systems state. That implies a broader spectrum of Fourier components than the initial spot frequency. I'm convinced You just forgot about o'l Fourier. I'm with You, discussing all that basics with the an eagerness as people are in for world first class stereo is quite tiresome. no offence |
#1045 | |
Account Disabled
Would You mind to check the windowing of Your spectrograph? Is it uniform or weighted (e/g Hanning), and how wide is it? Is it floating or stepping on the time axis? thanks a lot |
#1046 |
#1047 | |
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
#1048 | ||
#1049 | ||
Gees Earl, you said Quote:
#1050 |
John
Your comment then wasn't clear because it sounded like you were objecting to the whole claim, but at any rate, I don't agree with your analysis, unfortunatelky I don't have time to refute it right now. Morse never used the term MP, he never does, no one in acoustics does, so I suppose my mistake was ever using it in the first place as I still contend, as I always have, that it is ill applied to acoustics. |
