#1011 | ||
![]() In order to decorrelate a signal there needs to be a signal in the first place. For example, if there's a low frequency event in the left channel only, then your setup won't have that signal in the center channel and the right channel. But your optimization is based on the assumption that there IS that signal in the center and right channel. Now I don't only sound like a broken record, I feel like one. Next time I'll just link one of my last posts randomly. Best, Markus |
#1012 | |
Markus |
#1013 | |||
#1014 | |||
![]() Have a great day, Markus |
#1015 | |
Grounding for safety in audio equipment is not necessary and its often not even done. My AVR is not grounded, perfectly legal and reasonable. Grounds are mostly for power equipment (drills, table saws, etc. that take lots of current and have a tendancy to short to the case which is often metal. Audio equipment is very low amperage and the internal circuits are always issolated from the mains by a transformer. The only failure in equipment like this that could be a danger is a short to the case BEFORE the transformer, but this is VERY unlikely. As such its really overkill to use a power line ground. Albeit the equipment should be grounded somewhere just for noise and hum rejection, but this need be and only should be done at one place. |
#1016 | |
Earls method of using a single earthing point will work to sort out the hum, but might increase risk, primarily because not all users are knowledgeable enough to understand if there will be a safety issue for that particular set up. One way around the safety issue is to securely wire all the chassis together with 14 gauge wire and lift all ground lugs with an adaptor, except for the main receiver. Another way, if you have the knowhow (this is a DIY forum, after all), is to lift the internal chassis/circuit connections with about a 10 Ohm resistor. In parallel with the resistor, add a pair of antiparallel 25A diodes (a 25A bridge will work fine too - tie +/- together, and run the resistor across the AC connections). You might want to add 3nf or so, also in parallel, for RF ground. If your RCA connectors are directly connected to the chassis you will have to lift between the chassis and earth connection. If that helps, but not completely, you can try omitting the resistor and just use the diodes and cap. Sheldon |
#1017 | |
At first I didn't like the idea, since a cheap transformer will be bandwidth limited. But if it's only used on the sub channels, it seems acceptable. The use of a transformer on the RCA inputs to the sub would eliminate the hum, wouldn't it? (just thinking out loud - I'm working right now and can't test it one way or the other.) |
#1018 |
John
Yes, this should work as long as there is no ground path from the receiver to the amps or DCX. Sheldon "and lift all ground lugs with an adaptor" How is this any different than cutting off the ground lug? |
#1019 | |
With it being only on the subs, probably hiss will be a non-issue, and really only the hum would be the problem. This is why I was promoting active conversion from balanced to unbalanced. I would suggest doing this all the way to the subs including changing the input to a balanced input and mounting the circuit on the plate amp, so grounds can be properly isolated. |
#1020 | |
