Danley sound labs is introducing a new tapped horn called
TH-SPUD I think this is an interesting concept and so I tried to model a diy version. I'm thinking of using two B&C 8NDL51 drivers. They have a 7 mm xmax which I think should be enough for my small living room. Planned layout +/- 120 x120 x 25cm: Respons graph in Akabak with quarter wave resonating tube at 65Hz and 60Hz low pass: Hornresponse input: So what do you think? Will it work? Any design faults? |
#2 |
I didnt sim it, but 7mm xmax sounds really low for this low tuning. Check at what input power it runs out of excursion.
#3 |
Yes the power handling of this is not so high.
It runs out of xmax at only 12V rms This should give around 118dB max with corner placement. Would this be enough or should I better be looking for a more high excursion car audio driver? How would these car drivers compare on a distortion level against the PA driver I'm using now? |
#4 |
Hello,
better try two enclosures, different tuning, 3,7 and 2.5 m long, you get a better IMP and lower movement, look my double horns, a double TH for 5" ![]() ![]()
http://www.hm-moreart.de |
#5 |
In a tapped horn the phase varies wildly across the passband and above. Using enclosures with different tuning is strongly not recommended, it results in bad summing or cancellation. Phase matching a mid/bass system and a tapped horn is already difficult enough.
I use to feel like the small child in The Emperor's New Clothes tale |
#6 |
Hello,
did you read my double horns? : SAXOPHON, TROMBONE, POSAUNE, KORNETT and SUB FANFARE, special the measurements, best read "about what" in the middle: http://www.hm-moreart.de/11.htm
#7 |
G'day geitmans
The Tang Band W8-740 looks great in a box like this. 12mm X-max helps out the power situation quite a bit, too. Cheers William Cowan |
#8 |
An interesting driver for a low profile box:
http://www.parts-express.com/pe/psho...38&ctab=2#Tabs In an 18hz TH a series pair will be 96dB (at 20hz) in 2Pi and take 40V without exceeding x-max. Average about 118dB/40V, ±2dB from 18hz~60hz. Of course room gain or 1Pi loading would add to this.
Candidates for the Darwin Award should not read this author. |
#9 |
Anyone knwo where I can get that modeling software for my own folded horn project?
THANKS!!!! :-) |
| Tapped Horn for 18" bass | angeloitacare | Subwoofers | 14 | 28th March 2009 08:37 AM |
| "Dirt Cheap SE" 6BM8 spud amp | chrish | Tubes / Valves | 2 | 2nd July 2008 11:13 AM |
| Another tapped "horn" ? | phase_accurate | Subwoofers | 16 | 11th August 2007 09:05 AM |
| Page generated in 0.11119 seconds (88.42% PHP - 11.58% MySQL) with 11 queries |
