Old 5th January 2011, 10:45 PM   #111
Brett's Avatar
Originally Posted by slisgrinder View Post
I thought I'd try my luck here to find any directions for the DTS-10 plans. Do they even sell just the plans? And this build is pretty Awesome. Going back to post #30, how many revisions of those plans are there and what drivers are being used?
No, DSL do not sell the plans and the drivers are a proprietary design.
This thread is about the Spud, a different design to the DTS10.
Old 5th January 2011, 10:52 PM   #112
Oh well. Atleast this is an acceptable sub in a pair if I could build it. If I recall correctly, theres another SPUD clone on AVS?
Old 5th January 2011, 10:53 PM   #113
FlipC is offline FlipC  United States
The drivers are OEM for Danley.
The design isnt released per say. BUT from the Spud and all the info on the DTS-10 over at HTS you can figure it out.
Old 5th January 2011, 11:50 PM   #114
But it seems that this build had a lot more success and higher performance vs other builds I've read, especially the original design is still on post #30. Too bad DSL doesn't sell plans for the DTS-10 .
Old 6th January 2011, 04:48 PM   #115
kees52 is offline kees52  Netherlands
is the TH-SPUD also suitable to use single with the speakers connected on stereo channel? I saw something like that with ds-10 under 250 hz it is just mono.
one speaker per channel, one fase switched.
But on the other hand two of them can carry a coutch.
I will use them with a fostex box it is a horn to cover the bas under the 40 hz cutoff with the fostex.
Old 6th January 2011, 05:30 PM   #116
Brett's Avatar
I've never seen a DTS used with monoing done acoustically. I'd rather do it electrically and drive both drivers with the same signal in case there is some out of phase information between channels.
Old 6th January 2011, 05:52 PM   #117
thanks, I will build two, I can fit them under the couch so my WAF wil be pleased.
First I have to build the designed tube-mosfet amp, 400 watts each channel dc coupled with EL84 driver tubes or the EV81, test works now fine for over two years.
Old 6th January 2011, 06:08 PM   #118
*Comment removed*
Last edited by slisgrinder; 6th January 2011 at 06:09 PM. Reason: Sorry misunderstood, thought you found plans to build a DTS-10
Old 1st January 2012, 10:44 AM   #119
i know this thread is abit old now and there are probably better tapped horn designs out there, however i cannot find them, i curently have a single 12"eminence definimax horn that i tuned to 25hz (i was a noob, this sub is nice but the lower tuning runs out of xmax fairly fast below 30hz)
this thing is large enouth to be buried in, and quite a issue when moving house.
i now after half a year or working at a kitchen porter, have a house with a usable work area, i am interested in building a pair of these horns, i heard alot about leaked plans, but can only find these, (from two previous posts)
ImageShack® - Online Photo and Video Hosting
are these accurate? or did you make any modiforcations?
Old 1st January 2012, 08:14 PM   #120
tb46 is offline tb46  United States
Hi WaVeInFoRm,
The plans you are linking to are accurate, also: see Posts #21 and #30 for a comment by Tom Danley and for the (same) drawings.
Oliver
Tapped Horn for 18" bass angeloitacare Subwoofers 14 28th March 2009 07:37 AM
"Dirt Cheap SE" 6BM8 spud amp chrish Tubes / Valves 2 2nd July 2008 10:13 AM
Another tapped "horn" ? phase_accurate Subwoofers 16 11th August 2007 08:05 AM
Page generated in 0.09885 seconds (76.15% PHP - 23.85% MySQL) with 11 queries
