Old 2nd December 2008, 01:14 AM   #1
punkrokr1701's Avatar
Send a message via AIM to punkrokr1701 Send a message via MSN to punkrokr1701 Send a message via Yahoo to punkrokr1701
Wink MKIII approval
well I'm sure you great people who've been around are tired of me (;
I am mid way through build the BBBIB's, a lack of power tools is my main issue so those are still in progress. Meanwhile....
Christmas is around the corner and I've got my wish list. Compliments of the new step mom I have enough financial backing to feed my bass cravings.
So I've come down to the nitty gritty and I would like to know what you guys got to say.
I wanted not just bass. Anyone can make boomy, distorted , (ugly) bass. No I want smooth, solid, clean, chest pounding bass. Did I mention loud?
So I've enlisted the help of Dayton Audio to help me.
I'm set on the
Titanic MKIII in a 6.75 ft^3 cabinet @ 22 Hz Tuning powered by a Dayton 500w plate amp.
I'm not done, using 2 of Dayton's 4" Precison Ports for the best possible ports to minimize port resonance, coupled with a spiking system and some 1" cabinet insulation all around I believe I have found a winner.
I chose the 500w amp (although really 540w rms@ 4 ohms) because for one it's half the price of the 1000w amp at this time being as Xmas is coming up and I will not need more than that for what I want. I will also be using speaker gasket as too not gimp the most important seal.
As far as materials I can settle with OSB but I would like to ask the brilliant minds here as to what I should pursue. Any suggestions?
EDIT: Also I'm planning on a down firing design with the 2 ports on the front face. and the dimensions are 36"*18"*18" ID
Old 3rd December 2008, 09:17 AM   #2
Mikey p is offline Mikey p  Canada
Allowing for the displacement of the sub, ports and bracing, the internal volume of the cabinet needs to be 7.25 cu.ft. to get a net volume of 6.75 cu.ft. Using 3/4 inch building material, the outside dimensions of the cabinet would be 19" x 19" x 42.5"
Old 3rd December 2008, 07:31 PM   #3
FlipC is offline FlipC  United States
DO NOT USE OSB.
MDF or a nice grade plywood 3/4 ".
OSB will color your sound in a bad way. I only use it for test boxes.
What is really bad is if it "flakes" internally and you end up with a whistle or flutter. Ouch.
Old 4th December 2008, 08:58 PM   #4
lol im in drafting two and I'll still overlooking the obvious, thanks for pointing out the dimensions,
and yeh I'm thinking about a higher grade plywood, oak or birch is good for looks but expensive so maybe indoor pine?
Old 4th December 2008, 09:15 PM   #5
If you want them to look sound nice and look nice.
I would suggest using a veneer on top of the MDF. You could use a really nice hard wood veneer and still be as cheap as pine plywood.
MDF being about 20-25 bucks a sheet vs 30-35 for plywood. (my local and I haven't checked since gas went down)
Plus you really want to use 13 ply
plywood and not standard 9 that you find at most crap DIY chain stores. Yet another reason to use MDF.
Heatsink approval needed for lm3886 svbear Chip Amps 36 3rd August 2007 05:09 PM
LM3886 pcb approval wanted wxn Chip Amps 21 7th April 2005 04:56 PM
Need help with Spouse Approval ralph-bway Multi-Way 22 31st October 2004 04:22 PM
I'd like approval to build this design wigginjs Multi-Way 4 21st August 2004 02:03 AM
Page generated in 0.09053 seconds (75.44% PHP - 24.56% MySQL) with 10 queries
