Hey. I'm really into subs and would like to build something more complicated than a vented enclosure. I've done a bit of car audio, but I want to be able to use a larger sized woofer for the home (18" or 21").
I read a little bit about El-Pipo and thought about a way to compress the design. I've never worked with sonotube before so I don't know if it will work, but what do you guys think of this? ![]() ![]() ![]() ![]() ![]() ![]() Could it be done, and if so would it even be worth it? Could it somehow act as a horn because the two outer output pipes combined are larger than the first output pipe? Just throwing some ideas down |
#2 |
It would look really cool, but probably a lot of work... an easy way to double the length of a pipe is to put a baffle down the middle...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
Or pipe within a pipe........ Anyway, a tapped horn is a bit more complicated and many car audio sub drivers are excellent for the app and can probably match or beat an 18 or 21 TL with less power required if their published specs are reasonably accurate.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 | |
But wouldnt that somehow choke it? I would think with two 21" woofers and a 24" sonotube that this wouldnt be such a good idea. I don't have any experience here though so I could be wrong! |
#5 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Looks like a regular vented speaker, with large long ports.
| My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. | Spasticteapot | Multi-Way | 0 | 30th November 2006 04:16 AM |
| portable speaker idea : comments? | quiet | Multi-Way | 1 | 16th July 2005 02:52 AM |
| Wacky ESL idea | Serow | Planars & Exotics | 3 | 10th February 2005 12:11 AM |
| Adire Speaker Idea .. comments? | kfr01 | Multi-Way | 34 | 15th October 2004 03:37 PM |
| Is this a wacky idea? "Portable" Stereo... | jjdche | Multi-Way | 6 | 16th May 2004 06:00 AM |
| Page generated in 0.08777 seconds (76.39% PHP - 23.61% MySQL) with 10 queries |
