How to figure out unknown specs?
Old 17th November 2008, 07:27 AM   #1
FlipC is offline FlipC  United States
Default How to figure out unknown specs?
So if you only have the following info on a driver:
*Power handling: 300 watts RMS *VCdia: 2" *Le: 1.73 mH *Impedance: 8 ohms *Re: 5.98 ohms *Frequency range: 48-3,300 Hz *Magnet weight: 59 oz. *Fs: 33 Hz *SPL: 98.6 dB 1W/1m *Vas: 11.1 cu. ft. *Qms: 5.13 *Qes: 0.32 *Qts: 0.30 *Xmax: 3.0 mm *Dimensions: A: 15.15", B: 13.77", C: 5.94".
How can you figure out:
SD.Cms Mmd,Bl, and Rms ?
Old 17th November 2008, 07:38 AM   #2
simon5 is offline simon5  Canada
You can't.
You need at least one more parameter to fill out missing parameters.
You would need either Mmd, BL, Cms, Dd, Rms or Sd.
Sd woud be easy to approximate... then you get all missing ones.
DIYaudio for President !
Old 17th November 2008, 08:21 AM   #3
BHTX is offline BHTX  United States
BHTX's Avatar
I find myself having to do this often..
All you need to know is the average Sd for drivers of a given diameter.
Actually, I kinda have a bit of a window.. with pro drivers, I go a bit larger. With hi-fi woofers with larger surrounds, I usually go a bit smaller. Usually, I often just compare the Sd of similar drivers in WinISD Pro that I've already entered in the past. Works fine. Nothing's perfect, and the provided T-S parameters from manufacturers alone will leave you with far less accuracy than estimating Sd will.
Old 17th November 2008, 11:19 AM   #4
djk is offline djk
djk's Avatar
It's a 15, just use 850 for the SD.
Candidates for the Darwin Award should not read this author.
Old 17th November 2008, 05:17 PM   #5
I was suing 850 as SD but I was curious if
there was a way I didn't know about to figure it all out.
Thanks for the replies.
Old 17th November 2008, 06:12 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
850 in what units
- presumably 850 cm^2 or .0850 m^2
You can use the following as guess values for diameter for standard Lf units.
Frame size, piston diameter in mm, area in cm^2
4", 80mm, 50
5", 100mm, 78
6", 130mm, 130
8", 170mm, 225
10" 220mm, 345
12", 260mm, 530
15", 330mm, 855
18", 400mm, 1250
This is for woofers with "normal" excursion capability, of approx frame diameter in inches / 2 [in mm] - so 6mm for a 12" driver. Really long excursion woofers will have a smaller piston diameter.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Old 17th November 2008, 09:30 PM   #7
Thawach is offline Thawach  Thailand
Thawach's Avatar
FlipC please try to see online calculator. but some valves u must measure before.
http://www.radiocollection.net/tsp_calc.html
Reg
TW
Old 17th November 2008, 10:09 PM   #8
Dag Johansen is offline Dag Johansen  Norway
Default Re: How to figure out unknown specs?
If Sd=850 then:
Cms=0,3069 mm/N
Mmd=75,93 grams
BL=17,153 N/A
And Rms=3,069 kg/second
Dag
How to figure out unknown specs?Hide this!Advertise here!
Can Anyone figure this? duderduderini Tubes / Valves 10 31st August 2013 04:33 PM
How to replace a tweeter if the specs are unknown? jkesselman Multi-Way 7 12th January 2009 07:28 PM
How 2 figure out xover freq of unknown xovers? Bull Multi-Way 7 15th January 2008 02:19 AM
How to figure out unknown amp wattage??? Bull Solid State 11 1st April 2005 01:53 PM
help me figure this out please xdissent Solid State 7 23rd November 2003 09:57 AM
Copyright ©1999-2017 diyAudio
