Old 11th November 2008, 08:16 PM   #1
breez is offline breez  Finland
Question Voice coil gap tightness
How tight is the voice coil gap in common subwoofer drivers? I have a Peerless Resolution 15" driver and during break-in I may have accidentally overheated the voice coil.
This was a while back, but there must have been more than 100W rms power wasted as heat in the driver. Excursion was very high, but there were definitely no noises during the first few hours. Over the night a distinct *clip* sound developed. Pushing the cone in and out the coil rubbed a little depending how I pushed the cone. After cooling for several hours it didn't rub anymore unless I deliberately pushed the cone off-center.
Do you think the voice coil could be damaged a little? I presume it is normal for the voice coil to rub if cone is pushed the wrong way, but I can't remember how it was new.
Old 12th November 2008, 12:17 AM   #2
HK26147 is offline HK26147  United States
The gap is not very big, last recone kit I got came with shims, thicker than paper, approximately the thickness of card stock.
IMO You should not hear a rub at all if worked within normal limits.
I suspect an overheated and warped voice coil.
Old 12th November 2008, 12:43 AM   #3
Iain McNeill's Avatar
What I've seen happen is the laquer used to glue the VC windings together boils and bubbles forming a high spot. In particularly bad cases, the windings themselves can shift slightly. Clearances are in the order of 0.25mm so it's easy to have rub problems.
You can't fix this through the dust cap as the coil is on the other side of the former. Some manual cone abuse might work, especially if you're resigned to reconing.
Old 12th November 2008, 06:52 AM   #4
Looks like I just have to see how it works in a box and compare to a new one I ordered (plan is to build two boxes).
Old 14th November 2008, 09:12 PM   #5
Ok, the new one rubs too if pushed off-center. I guess the broken-in one is good to go. I'll see in a few months time when I'll get to building the boxes.
voice coil swap? pellis Multi-Way 0 15th July 2007 02:53 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 07:16 PM
recentering a Voice Coil wrl Multi-Way 6 23rd July 2004 02:25 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
Page generated in 0.07692 seconds (69.51% PHP - 30.49% MySQL) with 10 queries
