Old 11th November 2008, 08:14 PM   #1
drumsz is offline drumsz  United States
drumsz's Avatar
Default Question about cubic feet
Hi All
i have a few sets of plans i'm looking at colossus(fane),ciare,br 115,b&c sub 15
ok.... so is it better to go with the smaller or bigger suggested
volume i want a small foot print with tight punch will it hurt the driver over time ??
they will be ported or refelex ...... witch is better also ???
i'm more used to buying pro cabs but have good woodworking skills
and i'm bored sitting around have a kappa pro lf-2 15
my earlier post didn't get much
any help appreciated
thankx
Old 11th November 2008, 10:41 PM   #2
Pikefish's Avatar
Google says: 120L ported to 50Hz works well.
You can make it side, up or down firing, if it fits in 400mm then 400x400x800cm, narrow enough footprint? Have the port at the bottom for better half-space action, a slot-type port even so things are less likely to be able to crawl into it, and you can make it all from wood. Throw a little stuffing in there to damp those half-wave resonances and you're done. Some bracing along the long panels would probably be needed too.
Old 11th November 2008, 11:39 PM   #3
drumsz's Avatar
Default THANK YOU
THANXZ SO MUCH !!!!!!
I was looking at a cab simmiler to that but was un sure
nice job love it !!!!
Calculating box dimensions from cubic volume retroman Multi-Way 6 11th July 2009 04:06 AM
12" XLS in a 3.5 cubic sonotube? speakrsrfun Subwoofers 4 29th March 2009 02:05 AM
Q's about Cubic feet and driver selection evad Subwoofers 2 11th October 2007 03:37 PM
fostex 206 in 2.5 cubic foot box JimW Full Range 6 5th January 2005 05:50 PM
Page generated in 0.07214 seconds (72.94% PHP - 27.06% MySQL) with 10 queries
