#21 |
sorry!! GM i see the BIB pics with near field. and my imagine go to BIB sub but i can't fight this feeling. BIB with only 6" full range is very big and long. i'm thinking now that BIB=bigger is bad if i build a sub. okay i will go with TQWT.
#22 | |
You're welcome! LOL! I should have known! Long story short, this is what I call a ML -horn calculator that's based on some very erroneous rules-of-thumb, so the best thing you can do with it is to send it to the trash bin IMO. MJK's various write-ups on designing these, TLs, the TQWTs I'm suggesting and simming them using his Mathcad software is accurate enough, so tuning is no more 'hit or miss' than using HR and if you use his 'Classic TL' design routine, then even easier/quicker: http://www.quarter-wave.com/ WRT 'flat response', a driver with a <0.2 Qts only has a maximally flat response down to ~150 Hz in 2pi space, so placing them along a wall (1pi) or in a corner (0.5pi) to boost it down low to allow a lower tuning for a better match with the room's modes is desirable. If you mean 'flat' within its pass-band, then the TQWT can be as flat as any other vented alignment as it's just a large/long vented BR taken to its logical extreme, i.e. morphed into a reverse tapered pipe. Note that as a general rule-of-thumb, tuning a typical vented alignment below ~0.707*Fs isn't a good plan unless the driver is high Q (> ~0.403 Qts) and has enough Xmax, or ~22.5 Hz for this driver, though the high damping of TLs, etc., renders this mostly moot. This driver should work well in horns if the specs are reasonably accurate, but will be quite long/large to go low with any authority. Hmm, with only a single driver, getting 110 dB/20 Hz will require some serious room gain since the amount of power required to drive it to these levels would cause up to 6 dB of thermal power compression. Right, the driver's low Qts makes it a poor choice for a LRT alignment unless the mains are very inefficient. Anyway, here's a 10:1 CR TQWT in a ~6.49 ft^3 net cab using the assumption of a terminus area = dual 4" diameter vents that when mildly stuffed has an 18 Hz Fp in a single fold 4 ft. length assuming 0.75" thick construction: L = 94.5" SO = 251.3"^2 SL = 25.13"^2 zdriver (offset) = 9" zport = near/at the end stuffing density = 0.25 lbs/ft^3 of polyfil If you load it into HR, you'll see a much less flat response with a ~20 Hz Fp since it doesn't account for the effects of stuffing. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#23 | |
Would it better to slot port it (same as driver sd?), or to run the 4" ports? It seems like the required length of the ports would seriously disrupt wave formation. |
#24 | |
Is group delay more audible than phase? Actually what is the difference? A well designed subwoofer that integrates well with the mains has a characteristic and natural 'tight' sound with good 'snap' and 'attack'. Is it because of low group delay or good phase matching? 00600, Sorry didn't mean to change topic or hijack thread. |
#25 | |
The closed end (SO) = 251.3"^2, plenty of room to mount the driver normally. Note that the 9" is flexible, I just picked it since the driver's nominally 18", so if you want/need to shift it a little for an easy fit/whatever it's not a problem. The main thing is that the driver and terminus (vent opening) is near/at the floor for max boundary coupling, zero 'floor bounce'. The sim assumes the stuffing density is uniform the whole length of the TQWT. Stuffing is a tuning tweak though, so I recommend experimenting with less to begin with to find the best in-room tonal balance Vs a seamless blend to the mains. ??? This is a reverse tapered pipe, i.e. the whole cab is effectively one big, long tapered port tube, ergo the actual 'port' will be just a 25.13"^2 cutout at the small end (SL). GM
#26 | ||
I understand group delay as in the time difference between the signal reaching the driver, and the sound reaching your ear. IE: the first harmonic, say a 30hz tone from the sub reaching you within the proper time frame to match up with say the 6th harmonic (180hz) so that the "note" sounds natural. But I don't understand how to read the graph. Quote:
#27 |
what you're describing is more like a single fold tapered transmission line.
#28 | |
Group delay is the negative derivative of the phase WRT frequency. IOW, GD just tells us how fast the phase changes WRT frequency, so its just two ways to display acoustic phase rotation. Since our hearing acuity falls off with decreasing and increasing frequency below/above our critical hearing BW, the answer is it depends on the individual person's hearing acuity, all else being equal. Really, a ~flat in-room frequency response typically is the most important criteria to getting a good blend down low, another reason I prefer the low tuned EBS if only one or two subs is used. GM
#29 | |
GM
| Tuning a PR? | Animalnisse | Multi-Way | 2 | 11th December 2006 08:31 PM |
| tuning a box too low? | jaygeorge1979 | Subwoofers | 8 | 14th January 2006 10:44 PM |
| Tuning Qes Qts Bl Mms | P Zolt | Multi-Way | 10 | 21st April 2005 05:24 PM |
| Sub Box Tuning | Fazorcat | Subwoofers | 6 | 2nd March 2005 05:30 AM |
| Sub tuning | fortyquid | Subwoofers | 3 | 29th September 2003 07:33 PM |
| Page generated in 0.13932 seconds (83.14% PHP - 16.86% MySQL) with 11 queries |
