http://www.vikash.info/audio/xls10/
I have to replace the sub amp with another model, the one he specifies is not available in NA. Would I need one that has a plastic cover over the internals? Thanks, Brendan |
#2 |
If you have average to good woodworking skills, yes, this is a good beginner project. If you are unsure about your woodworking skills, a sealed design would be easier.
You could swap the amplifier for another one, no problems. No need for a plastic cover, just check if the amplifier is fully sealed and correct the design for the amplifier size differences. Some plate amplifiers without rear covers are fully sealed, some are not. It's really important that you have no air leaks at all, since this is a passive radiator design.
DIYaudio for President ! |
#3 |
The only thing which would be even easier is a closed box, i.e. the same thing just without the passive radiator. A PR box is in its essence like a bassreflex, so you get a few dB more output around the low cutoff but need a highpass filter, because below a certain frequency the excursion gets very high. Closed boxes are more error insensitive and have a slightly better sound quality, but less maximum spl.
#4 | |
#5 |
Did it Himself
A sealed design with the XLS10 is a more difficult project IMO as you need equalisation to get a decent bass response.
I personally don't believe you will gain anything using thicker wood for the walls only, the cabinet is already heavily braced.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 | |
It needs to be totally fully perfectly sealed. You can achieve it with caulking inside the enclosure. After the box was fully built and glued, I personally achieved a perfect joint by using excess wood glue, until I got a perfect inner joint on all the inside. (Yes, I'm crazy) For sealing the amplifier and the driver, you can use some double sided adhesive weatherstripping, or some caulking. Some drivers and amplifiers already come with a strip of foam, that when screwed down, it seals itself. As richie00boy said, doubling the walls won't help you much. The box will only be much heavier and also it will be a bit bigger. If you want to countersink the driver on the other hand, you could double up the baffle. Countersinking ain't that useful for subwoofers, unless you like the aesthetics of it. If you have good woodworking skills, go for it. I built my first subwoofer with a basic jigsaw, a drill, a table saw, sand paper and patience. With a circle jig and a router, it will be easy for you. Good luck !
#7 |
Hmm, even with a very low Vas by PR standards, I wonder how well a down firing PR will work over time sag wise, especially if exercised regularly with pipe organ and/or HT LFE.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
Speakerholic
That's what I'd worry about.
#9 |
I agree with GM and Cal Weldon, I should have checked the design completely hehe.
Interesting design. I don't think it's a good choice. I'd at least put the driver downfiring and the passive frontfiring... Or even better, use dual passive side firing with the driver front firing.
#10 |
OK, yesterday I was just 'thinking out loud' when I posted my concern, but I found it hard to believe one of our moderators wouldn't do a performance update to such a meticulous presentation if it didn't work well, so out of curiosity I used Adire's downward sag math to calc/confirm it and found that the published 'Cms' is listed as mm/N for both driver and PR, but is in m/N.
Corrected to mm/N: 830452 = ~0.69 mm = ~5.52% sag 830841 = ~1.99 mm = ~9.05% Adire recommends < 5%, so if you accept their math and I didn't screw up (a real possibility, so someone please double check it), then the driver may/may not be OK in a down firing app depending on how hard it's likely to be driven, but the PR is a no-no if driven hard. Regardless, I asked Vikash to give his thoughts/real world experience since IMO this is the final arbiter of what's acceptable. GM
| This a good beginner 'scope? | sansbury | Equipment & Tools | 59 | 1st May 2007 12:57 PM |
| Project for a beginner | bg4533 | Full Range | 11 | 29th August 2005 08:51 PM |
| Beginner DIY project | paulb | Solid State | 1 | 2nd January 2002 12:00 AM |
| Page generated in 0.10955 seconds (80.68% PHP - 19.32% MySQL) with 10 queries |
