Old 30th October 2008, 06:15 AM   #1
Default outdoor test question
If the only place I can test outdoors is a large EMPTY parking lot. Are there any suggestions for adjusting readings with an oscillator and a rat shack db meter. My laptop died so no true rta.
Should the cabinet be on the ground or elevated?
For a TH or folded sub, Mouth down or up (upside down)?
I'm going to test at 100w 10m, then with a 35hz cutoff filter in line.
I also want to test max spl to see what the box will do in combat.
Thanks.
Old 30th October 2008, 09:20 AM   #2
simon5 is offline simon5  Canada
You should elevate the speaker if you want to avoid early floor reflection.
You could keep it on the floor if you want to see what some floor interaction will do to the frequency response...
Max SPL tests outdoors are a bit misleading if your speaker will play indoors. The reading will be MUCH higher indoors.
DIYaudio for President !
Outdoor speakers-question barn Multi-Way 0 9th December 2008 11:04 AM
stupid question and strange testing method ,da pinch test fortuosity Solid State 11 7th February 2006 03:35 AM
Outdoor help please?!?! idqracing Multi-Way 2 3rd November 2005 02:36 AM
Outdoor speaker question JohnS Multi-Way 6 17th June 2002 09:54 PM
Page generated in 0.06381 seconds (67.42% PHP - 32.58% MySQL) with 10 queries
