How do I make driver holes??
Old 29th October 2008, 08:37 PM   #1
rtate is offline rtate  Canada
Default How do I make driver holes??
I am about to start construction on a Rythmik 12" sub made from 3/4" mdf.
The driver cuttout is 11 3/16"
How do I go about making the hole so that it's perfectly round?
I don't own a router, should I be looking at purchasing one?
Old 29th October 2008, 08:42 PM   #2
craigwalsh is offline craigwalsh  United States
You can also use a jigsaw, the way I've done it up until recently. In my experience, jigsaws make less than perfect round holes. Okay, it's not the jigsaw, it's the operator. There may be simple jigs one can use for making nice round holes with a jigsaw. But, routers are great for this stuff, esp. with MDF. I've just started using one for template and hole-cutting. Boy, it is very nice and quick and the edges made are really clean. I don't think I'll go back to using a jigsaw for this.
I'd look into getting a router and circle cutting jig if possible.
Old 29th October 2008, 08:53 PM   #3
Drew Eckhardt is offline Drew Eckhardt  United States
Default Re: How do I make driver holes??
Plunge router, circle jig, and spiral up-cut bit.
While you can buy a circle jig, making one is as simple as matching the router's mounting pattern in a piece of scrap plywood, driling holes at the radiuses you want, and making a bigger hole to clear the bit. You can screw the inside cutout to something behind it, or stop your cut short of going all the way through, finish with a jig saw, and clean it up with a flush trim or pattern bit. Make three passes. It'll stress the bit less (there's not much metal in a 1/4" spiral bit's web).
The other reason you want a router is that it makes it easier to make perfect cabinets. You start with four sides that are the same height, two of which are thinner than the intended width in that dimension by two material thicknesses (probably .750"). Rather than trying to make the top and bottom exactly match that width or sand (MDF Is horrid) you can cut it 1/8" oversized and trim to fit with a flush trim bit.
Routers are a lot of fun; mine has become my favorite power tool.
Old 29th October 2008, 09:00 PM   #4
Thanks for the info!!
I was looking a a circle jig at Lee Valley but it only went up to
7 1/2" and i need 11 3/16"....
Old 29th October 2008, 09:04 PM   #5
SpeakerScott is offline SpeakerScott  United States
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Jasper Tools...great stuff...
http://www.jaspertools.com/
https://www.facebook.com/DIYRM/ See FaceBook page for >100 pages of design guides and articles.....
Old 29th October 2008, 09:14 PM   #6
I own a set. While they're nice, I've also made my own circle jigs for larger radiuses around 1.5, 5, and 12'.
After doing that I decided that $40 to save 10 minutes the first time and a minute each time I needed new diameters wasn't worthwhile.
The 1/8" dowel pin as a pivot is nicer than a nail but shouldn't run you over $1 at a decent hardware store.
Old 29th October 2008, 11:08 PM   #7
littlemike is offline littlemike  United States
A router and circle jig is my preferred way to speaker cutouts (at least larger ones)
I have the Jasper Jigs too, they are nice.
You can certainly make your own jig for a lot less $$$, it will work as well, but might be a little bit more work to set up initially.
Old 30th October 2008, 12:27 AM   #8
The jasper jig looks good but $40 for 1 sub...
I'm not sure if it is cost effective...
Anybody want to sell a used jasper??
Old 30th October 2008, 12:41 AM   #9
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
It's not a big deal to make your own.
Gee, if you think you can build a speaker, you sure enough should be able to make a circle jig. It doesn't need to be fancy - a piece of thin hardboard will do. DIY.
Old 30th October 2008, 12:51 AM   #10
Wow...a home made circle cutting jig, with a home made plunge router using a flush cut bit...
I'm impressed, and I feel inadequate since I just bought mine...and didn't build it...jeez..
-Scott
How do I make driver holes??Hide this!Advertise here!
cutting speaker carpet around recessed driver holes noodle_snacks Multi-Way 13 17th June 2006 07:43 AM
How do I repair a crack between driver holes in a baffle? GuyPanico Multi-Way 5 12th July 2005 06:19 PM
ProAc 2.5 driver mounting holes Saci Multi-Way 4 10th April 2003 03:39 PM
Best method for cutting driver holes? dc Multi-Way 16 29th May 2002 12:27 PM
Anyone can make your own speaker driver! Matt MacBeth Multi-Way 8 20th May 2002 01:02 PM
Copyright ©1999-2017 diyAudio
