diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Subwoofers (http://www.diyaudio.com/forums/subwoofers/)
-   -   Volume of driver and plate amp? (http://www.diyaudio.com/forums/subwoofers/132167-volume-driver-plate-amp.html)
Lewis Moon 29th October 2008 12:54 AM
Is there a usual rule of thumb for the volume of the plate amp and driver on a sub? I'm using WinISD. I can calculate it (I calculate the volume of irregular lakes as part of my job) but I'm....um....lazy.:cannotbe:
simon5 29th October 2008 07:39 AM
There's no rule of thumb AFAIK...
You can approximate it by calculating that a cone volume is a third of what a cylinder of same height IIRC then adding some for basket and magnet...
You can seal your woofer into a strong plastic bag and dump it in water and measure displacement...
For the plate amp, it depends on the plate amp, some have an open back and take minimum space that you could approximate to barely none, some are closed back with a big rectangular metal plate, so easy to mesure volume.
Good luck !
Copyright 1999-2017 diyAudio
