Old 26th October 2008, 09:29 PM   #1
Default Reflex vs sealed
Have there ever been any double-blind listening tests between ported and sealed subs with the same in-room response (at listening position, of course)? Just wondering how many people who prefer sealed subs to ported subs would consistently pick out sealed subs in such a test (low-to-medium SPL to prevent the advantage from going to the ported subs).
Old 26th October 2008, 10:11 PM   #2
RobWells's Avatar
You mention that the ported would have an advantage over sealed at high volumes.. What about if your source material has plenty of output below the 'advantaged' ported subs tuning frequency ?
Rob.
Old 26th October 2008, 10:35 PM   #3
infinia is offline infinia  United States
infinia's Avatar
I'd be interested in a test similar to this. but looking specifically at group delay differences between a BR an a AS.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 26th October 2008, 10:37 PM   #4
Cloth Ears's Avatar
With suitable source material, it's fairly easy to tell the difference, unless your ported sub is quite a large alignment. Simply, the sealed sub will roll-off at around 12dB/octave, and the ported at around 24dB/octave (vast simplification here!).
Assuming un EQ'd bass (big assumption), the ported will have a flatter frequency response down to it's port tuning frequency and will then fade away quite quickly. The sealed will start rolling off sooner, but extend out more. If you take room 'boost' into account (which may be difficult do to reflection nodes), then you might find your ported sub to sound a lot boomier in the frequecy range between port frequency and where the room reflections start boosting the bass. The sealed, due to it's roll-off at around the same rate as the room boost, may not show this effect.
But, it really depends on the subwoofer and the room. There are many ported subs on the market, due it being quite cheap to get reasonable levels of bass out of a ported box (compared to a sealed one using the same amplification and size). I feel that you get better bass from a sealed than a ported - but that's a personal preference (and I'm talking below 50Hz, here). Others prefer open baffle (but I can't justify the size for a 20-50Hz subby) or bass horn (ditto) or tapped horn (haven't tried).
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 26th October 2008, 10:42 PM   #5
Rob.
Designing a ported sub such that its tuning frequency is above that of the lowest frequency required of it is rather disingenuous, wouldn't you say? This isn't supposed to be a test of good design vs bad design. Picking crap does nobody good.
Old 26th October 2008, 10:43 PM   #6
Yes, which is why I qualified my post with "with the same in-room response".
Old 26th October 2008, 10:45 PM   #7
MJL21193's Avatar
Default Re: Reflex vs sealed
Not many I'd guess.
Old 26th October 2008, 10:53 PM   #8
infinia's Avatar
Default Re: Re: Reflex vs sealed
Originally posted by MJL21193
Not many I'd guess.
Because there are not many good woofers made for AS any more. i.e. Fs<20 Hz with soft suspension. Apparently they are very hard to make with good QC.
Old 26th October 2008, 10:56 PM   #9
Default Re: Re: Re: Reflex vs sealed
Hope on the horizon
http://www.aespeakers.com/drivers.php?driver_id=8
Old 26th October 2008, 11:02 PM   #10
MJL21193's Avatar
I didn't have any problem finding some. By chance I found 4 relatively new 15" woofers at Goodwill that are perfect for acoustic suspension.
I used two for my workshop speakers:
Audio Reflex CE-431 rpapps Everything Else 0 30th October 2005 05:31 AM
Sealed midbass vs BR, why not sealed ? mbon Multi-Way 3 16th June 2004 10:50 AM
Port reflex or sealed mark.carline Multi-Way 7 11th May 2004 07:08 AM
Bass Reflex Guss Multi-Way 1 15th December 2003 02:33 AM
Page generated in 0.12934 seconds (75.26% PHP - 24.74% MySQL) with 11 queries
