#31 |
Infinia, I don't do exactly the same thing that simon5 does - I just use the same approach.
It's not quite an EBS tuning, as the target response is a curve that slopes gently downward at about 3 dB per octave, then of course rolls off rapidly below the tuning frequency. Perhaps this approach deserves its own acronym. I propose "RGC", for "Room Gain Complimentary" tuning. It's not really all that difficult, but like anything else you have to do some modelling to find woofers that will do what you want in a box size you can live with. Duke |
#32 |
Here's an example...
This is an example, using Dan Wiggins ShivaMKIV. I will post the FR curve shortly.
DIYaudio for President ! |
#33 |
Here's the FR curve measured in room. It was measured by hand and plotted in Excel. It's not perfect but it does give an idea.
#34 |
Nice... gets very loud also, no subsonic filter needed.
How did you measure in room?
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#35 |
It was measured using a simple Ratshack dB meter on the C weighted rating and using a compensation chart.
As I said, not perfect, but it gives an idea.
#36 |
Simon5, thanks for posting an example. I didn't have time to yesterday.
Regarding your posted in-room measurement, I would have expected to see a peak-and-dip pattern at the microphone position due to room interaction. Is that a spliced close-miked measurement, or an average of several microphone locations? Or, were you using warble-tones? Thanks, Duke |
#37 | |
That's why I stated several times that it's not perfect, but it gives an idea. You could post a better design with a better FR curve, I'm sure !
| Audio Reflex CE-431 | rpapps | Everything Else | 0 | 30th October 2005 05:31 AM |
| Sealed midbass vs BR, why not sealed ? | mbon | Multi-Way | 3 | 16th June 2004 10:50 AM |
| Port reflex or sealed | mark.carline | Multi-Way | 7 | 11th May 2004 07:08 AM |
| Bass Reflex | Guss | Multi-Way | 1 | 15th December 2003 02:33 AM |
| Page generated in 0.08603 seconds (75.53% PHP - 24.47% MySQL) with 11 queries |
