I just got the Logitech x-530 5.1 "surround sound" setup. The speakers are fine except for the woofer. When i have the bass volume (on the back of the woofer) above about 1/4 then whenever i turn up the volume moderately (to about 1/2), The woofer begins to crackle when deep bass is played. If i turn the bass up
I don't really know much about speakers or anything. I tried to take the woofer apart but the power cord keeps the metal plate on the back from being taken off. There is no other way to get it (atleast that i could find.) Can anyone give me any fixes or advice? Thanks. |
#2 |
It could either be the amp clipping, or the subwoofer being driven to over-excursion and it's cone crashing into stuff.
The simple fix for it is to turn the sub volume dial back down. A better one, if possible, would be to adjust the equaliser in whatever you're driving it with, presumably the computer. Turn down frequencies below 40Hz, as the sub probably fails miserably at producing these frequencies and ends up floundering about and making crackling sounds. Some soundcard controllers have this, as do media players, but for a fix-all you'll need to find the soundcard's equaliser. |
#3 |
Hi - I have these same speakers but the 2.1 version...
All i know is (from looking) that the subwoofer won't move any further after a point, and it is when it has moved furthest that is crackles - so yes, i think it is the sub driver but i don't think there is much you can do about it as i tryed to replace the driver in mine, just to see what would happen.. but i couldn't get in - same problem as you The trick is to get an amp, some reasonable bookshelf speakers and a big sub - you will be fine with those =) have a look at http://www.richersounds.com/showprod...HTD-50-MAP-SIL or better if you want the same sound, but without the crackles Hope this helps
#4 |
If you want deep bass, you need to upgrade. As Pikefish said, I doubt your unit is faulty, I think it's by design.
If you want to stay with Logitech, there's the Z5500 Digital. If you just got it, and think it's faulty, why not bring it back to store and try another unit to be sure ?
DIYaudio for President ! |
#5 |
If that still doesn't fix the problem. You might have small wires on the line into/out of the sub. This also causes problems like this sometimes. +1 vote for getting another subwoofer. Keep the old sub for lower power systems (such as computer) or sell it or destroy it.
| tube amp subwoofer hum problem | timolien | Tubes / Valves | 3 | 13th September 2006 02:41 PM |
| subwoofer problem.HELP!! | sachi | Subwoofers | 6 | 2nd March 2005 07:12 PM |
| Subwoofer distortion problem | lordy | Subwoofers | 11 | 16th January 2004 03:43 AM |
| RCA Subwoofer problem | soundNERD | Subwoofers | 4 | 6th December 2003 02:13 AM |
| Page generated in 0.09060 seconds (77.65% PHP - 22.35% MySQL) with 10 queries |
