Does this sound like a decent HT sub
Old 16th October 2008, 07:28 PM   #1
nikbrewer is offline nikbrewer  United States
Default Does this sound like a decent HT sub
ok, this is my first real pot on here. I hang out at parts express tech-talk most the time.
I am wanting to build a decent sub for my loft. This is where mt 42" plasa is, basically my media room. room is 11' deep, 12' wide, open on one side to the stair way, see pics below.
stereo system consists of pioneer vsx-818v reciever, my tritrix front ported towers. i am currently building a sealed tritrix for my cneter, and wil build 2 WT for the rear surrond to replace my sony stuff. ialso have a sony SA-WMS230 powered sub.
I dont want a cube of a sub box, i want somethign different and hidden.
i have 3 ideas for a sub box.
1st: 2 tang band 6.5" subs in a 17.25 x 36.75 x 5.5" box. it would have about .8 cubic feet of air, a 4" x4" x38" port powered by the dayton 100 watt amp.
looks to kit 37 hz at -3 db, spl of about 106 db, port velocity of 10 mps.
this would fit up under my tv stand and be totally hidden.
second option is to put a sub in my sofa. i have half a sectional sofa, which i built abox on the end and covered to make a arm. i could remake this to include a sub box.
1st version of this would be a dayton 8" dvc sub w/ 100 watt dayton amp.
box would be 24 1/2" x 35" x 6", port would be 4.5" x 4" x 41"
1.45 cubic feet air space
looks like 26 hz at -3 db, spl 104.5 hz, port velocity 10.5 mps. this looks like a promising set up.
the third is the hard hitter
dayton rss265HF-4 with either the dayton 240 or bash 300 amp.
box would be 35 x 25 x 7, port would be 4.75 x 5.25 x 41. air space 1.75 cunic feet
29 hz at -3 db, 110.5 spl, port velocity 12.5 mps.
Now cost is an option. i will spend more if its truely worth it. these setup go from under 100 almost to right at 300$.
i need feed back please
here are pics of the room it would go in
front speakers
Old 17th October 2008, 08:33 PM   #2
badman is offline badman  United States
badman's Avatar
Default Bigger is better
Always go for the biggest sub you can. A 6.5" is not a woofer, much less a subwoofer. You can stretch and call it a midwoof. An 8" is still a midwoofer, to my way of thinking. Go with the big one and live happy. With the little ones, you'll run out of output, and eventually wind up building the big one anyway.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 17th October 2008, 10:02 PM   #3
GM is offline GM  United States
GM's Avatar
Note that 38 - 41" long vents will have strong enough organ pipe harmonics to comb filter with the mains outputs, which may be distracting and stuffing to attenuate them will audibly reduce output.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th May 2009, 05:35 PM   #4
gvr4ever is offline gvr4ever  United States
The TB min subs are fun and NOT a joke. For anyone not familiar with them, anything under 8" would sound like a joke, but they are not.
http://www.parts-express.com/project...ject=Boogieman
That would make a good under the table sub. Probably under the sofa would be better. It could probably make a player skip if you tried to put it under your components.
The downside, it's not really cost effective. One large sub is proven and works. I'm actually making one with 4 of the smaller 5 1/4" subs. I wouldn't even plan a project like that, but I had one in a computer 2.1 system that got taken apart. I had two from a car that I sold. Then I got another one so I could do 4 in one sub. I got the first three for $19 each, but I had to pay $33 for that last one. Software shows -3 at 37hz and some people are claiming 35hz just with the 5 1/4 subs. I'm in the process of setting up speaker workshop to take actual measurements, but my sub is being built right now.
The TB subs some how have low distortion with extreme xmas. Goes against everything I've ever read about lower xmas and a bigger woofer is better. I would only choose them for a car or HT though. They are not audiophile level of low distortion, but very nice, and fun to play with.
Old 27th May 2009, 12:24 PM   #5
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
there is a nice tapped horn design with the 6" TB sub, iirc it is on www.volvotreter.de
Old 27th May 2009, 09:18 PM   #6
Here is what I have been working on. Just 4 TB W5-1138SM's and a Dayton 25W plate amp.
Almost done...
Does this sound like a decent HT subHide this!Advertise here!
original la sound amps.. crappy? decent? ppia600 Car Audio 13 17th December 2008 05:12 AM
Decent sound for the masses Conrad Hoffman Everything Else 3 26th December 2007 04:25 AM
Need a decent kit Konnan101 Solid State 4 5th February 2004 07:02 PM
Where to get a decent VFD? BrianGT Digital Source 18 6th October 2002 05:23 PM
