New AV12X, AV12H and AV15X, AV15H from Acoustic Elegance (former Stryke) New AV12X, AV12H and AV15X, AV15H from Acoustic Elegance (former Stryke) - diyAudio
Old 10th October 2008, 10:50 PM   #1
simon5 is offline simon5  Canada
Default New AV12X, AV12H and AV15X, AV15H from Acoustic Elegance (former Stryke)
Hi guys,
Did you saw the new drivers available from Acoustic Elegance ? John had alot of problems to bring them to market, but now they are ready and he's taking pre-orders with a pre-order rebate !
199$ for the AV12H or AV12X
219$ for the AV15H or AV15X
My personnal favorite is the AV15H since it's modeling very well in a large vented box or passive radiator box. I plan to replace my old Adire Audio Shiva with it... that will be a serious upgrade !
I think the drivers have a bit high Fs IMHO but other than that, they look great with that aluminium cone. The Qts is OK and excursion is a good 23mm with 1000W power handling.
Here's some specs :
AV12-X
FS: 26.7Hz
Qms: 3.67
Vas: 69L
Cms: .22mm/N
Mms: 161g
Rms: 7.32
Xmax: 23mm
Xmech: 32mm
Sd: 471sqcm
Vd p-p: 2.16L
Qes: .36
Re: 3.2ohm
Le: .196mH
Z: 4ohm
Bl: 15.6Tm
Pe: 1000W
Qts: .32
qWSPL: 87.7db
2.83V: 91.7dB
AV12-H
FS: 24Hz
Qms: 4.5
Vas: 69L
Cms: .22mm/N
Mms: 198g
Rms: 6.77
Xmax: 23mm
Xmech: 32mm
Sd: 471sqcm
Vd p-p: 2.16L
Qes: .26
Re: 2.7ohm
Le: .28mH
Z: 4ohm
Bl: 17.6Tm
Pe: 1000W
Qts: .25
qWSPL: 87.7db
2.83V: 92.4dB
AV15-X
FS: 24Hz
Qms: 4.1
Vas: 197L
Cms: .22mm/N
Mms: 200g
Rms: 7.4
Xmax: 23mm
Xmech: 32mm
Sd: 794sqcm
Vd p-p: 3.67L
Qes: .39
Re: 3.2ohm
Le: .196mH
Z: 4ohm
Bl: 15.6Tm
Pe: 1000W
Qts: .36
qWSPL: 90.4db
2.83V: 94.3dB
AV15-H
FS: 22Hz
Qms: 4.86
Vas: 197L
Cms: .22mm/N
Mms: 235g
Rms: 6.7
Xmax: 23mm
Xmech: 32mm
Sd: 794sqcm
Vd p-p: 3.67L
Qes: .29
Re: 2.7ohm
Le: .28mH
Z: 4ohm
Bl: 17.6Tm
Pe: 1000W
Qts: .27
qWSPL: 90.7db
2.83V: 95.5dB
For more information, here's the thread on AE forums :
http://www.aespeakers.com/phpbb2/vie...php?f=3&t=1715
That's not mentionning that he still manufactures the whole Lambda Acoustics line of products with Nick that's came back from retirement...
DIYaudio for President !
Old 10th October 2008, 10:58 PM   #2
454Casull is offline 454Casull  Canada
Clickable link
Old 10th October 2008, 11:03 PM   #3
Thanks 454Casull for correcting my mistake. I should be more careful hehe !
I edited my post to correct the mistake also.
Old 14th October 2008, 12:27 AM   #4
Taterworks is offline Taterworks  United States
Taterworks's Avatar
I'm glad to see these drivers made it back into production. At the preorder price, those AV12s look like a real deal. I've got an AV12 from back when TC Sounds built them for Stryke Audio, and I think I might move up to the new woofer for whatever improvement in musicality I can get, though the originals were some of the cleanest bass drivers ever, period.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 14th October 2008, 03:34 AM   #5
GM is offline GM  United States
GM's Avatar
Yeah, the AV12-X looks good in a ~3.3 ft^3, 20 Hz TQWT and ~11.7 ft^3, 13 Hz TH.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th October 2008, 05:56 AM   #6
Should be even better with that full copper sleeve on the pole...
Originally posted by GM
Yeah, the AV12-X looks good in a [...] ~11.7 ft^3, 13 Hz TH.
13 Hz and 12 cu.ft !
Damn GM, that's some serious monster !
Show us pics if you build it...
Old 14th October 2008, 02:25 PM   #7
GM's Avatar
Sorry, no plans to build any, just thought I'd 'run the numbers' since its specs looked like they might work in a semi-reasonable size cab.
GM
Old 24th October 2008, 04:00 PM   #8
John_E_Janowitz is offline John_E_Janowitz  United States
Send a message via MSN to John_E_Janowitz
hey GM,
I have very little experience with the tapped horns at all. Any chance you could post up a simulation?
John
Old 24th October 2008, 05:49 PM   #9
GM's Avatar
Greets!
Just did one, which includes a 0.3 ohms/4 mH inductor, though of course a different value may be required:
GM
Old 24th October 2008, 06:01 PM   #10
GM's Avatar
Half space (2pi), 50 V input to reach ~24.9 mm excursion for reference:
GM
File Type: gif ae av12-x 13.35-148.33 hz conic th - (0.3 ohms, 4 mh).gif (20.4 KB, 275 views)
New AV12X, AV12H and AV15X, AV15H from Acoustic Elegance (former Stryke)Hide this!Advertise here!
Acoustic Elegance TD12 - which version? Defo Multi-Way 18 29th April 2009 05:56 PM
Many deals currently at Acoustic Elegance (former Stryke Audio) simon5 Subwoofers 14 9th December 2007 04:23 AM
FYI : Acoustic Elegance (AKA Stryke) reopened and IB15 are available again... simon5 Subwoofers 1 29th August 2007 03:16 AM
Acoustic Elegance coming summer 2006? bickeler Subwoofers 0 2nd May 2006 09:49 PM
Acoustic Elegance/Lambda? Sheldon Subwoofers 33 5th November 2005 04:11 PM
Copyright ©1999-2017 diyAudio
