Where to crossover, don't want audible bass
Old 6th October 2008, 09:43 AM   #11
R.I.P.
You can try a 2nd order rolloff on the IB. Theoretically with the 6dB/
octave gain of the IB you might get a more room friendly response.
If you have plenty of power for the IB you can try a series resistor
which will increase bass around the IB drivers Fs by changing Q.
/sreten.
Old 6th October 2008, 11:16 AM   #12
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Hello
You can try a 2nd order rolloff on the IB. Theoretically with the 6dB/ octave gain of the IB you might get a more room friendly response.
Sreten, are you saying put a highpass infront?
If you have plenty of power for the IB you can try a series resistor which will increase bass around the IB drivers Fs by changing Q
How much power, and how do I calculate the resistor.
Analog filters above 24dB/oct are not recommended due to the increasing group delay.
peaks or nasty out of band resonances in the low frequency system
Eva, hence the Behringer?
Can't the Behringer be emulated, I got a spare PC and soundcard?
Thankyou, Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 6th October 2008, 12:01 PM   #13
R.I.P.
Default Re: Hello
Thankyou, Mike
No. The low pass is tailored to include the baffle loss.
http://82.95.237.142/mhsoft/spk_calc.asp#newqts
how much extra power depends on the series resistor.
See MJK'S open baffle articles here : http://quarter-wave.com/
/sreten.
Old 6th October 2008, 01:36 PM   #14
mikee55's Avatar
Default New Qts
Hi all, I had a go at the calculator. Does it look right.
Cheers Mike
Old 6th October 2008, 01:46 PM   #15
R.I.P.
Default Re: New Qts
Cheers Mike
You've lost me. Rs = driver Re and R = series resistance.
I've no idea what Rs in your specs are. Assuming Re = 3.7R.
for 0.5R I get Q=0.97, 1R Q=1.07, 2R Q=1.27 etc.
/sreten.
Old 6th October 2008, 06:06 PM   #16
mikee55's Avatar
Default Hello
Just changed the Xover frequency to 23hz, and have a reasonable compromise. I want to understand more, about open baffles. I think, I could replace my Mordaunt Short MS40's with some OB units??
I'd be lucky if I can use the drivers from the M Shorts. Thought provoking.
Thank you all for your help.
Mike
Where to crossover, don't want audible bassHide this!Advertise here!
Acoustat bass crossover? The Peasant Planars & Exotics 12 6th May 2006 12:00 AM
What is 'audible'? steve Everything Else 3 13th September 2004 10:56 PM
Resistors in x-over - audible? TNT Multi-Way 0 3rd August 2004 08:04 PM
series crossover with 2.5 way bass madinoz Multi-Way 18 8th June 2004 12:55 AM
What are the common audible crossover points? dih1118 Multi-Way 2 22nd September 2003 09:12 PM
