Old 4th October 2008, 02:05 AM   #1
Question Need help with a new sub, a couple of n00bish questions
I'm trying to figure out how to figure out what size amp i need for this woofer
Rockford Fosgate P1S415:
15" 4-ohm subwoofer
molded polypropylene woofer cone with poly-foam surround
17-gauge steel bend frame
power range: 50-200 watts RMS (400 watts peak power)
frequency response: 24-250 Hz
sensitivity: 87 dB
top-mount depth: 6-5/16"
Polk Audio MM1240D:
power range: 100-360 watts RMS (180 watts RMS per coil)
peak power handling: 720 watts
frequency response: 27-200 Hz
sensitivity: 88 dB
top-mount depth: 4-5/8"
sealed box volume: 0.88 cubic feet
im planning on making a ported enclosure
for this kinda driver i only need a 250watt amp?
I bought both $50 each in box so no complaints also im using one for my car but that takes back seat for the one for the home theater
http://img528.imageshack.us/my.php?i...2773312mr2.jpg
Theile/Small parameters:
RF:
http://www.rockfordfosgate.com/rftec...15_revA-TS.pdf
PA:
http://www.polkaudio.com/downloads/m..._Sub_WebMN.pdf
the wall with the tv to the kitchen is about 30 feet
Thanks a bunch from a confused little friend
alfa
Old 4th October 2008, 07:07 AM   #2
dangus is offline dangus  Canada
Power isn't critical; there's a lot of leeway for a home theater application because the bass is usually intermittent. Not a like a car or party situation where it may be pounding at full volume for extended periods.
200 watts seems like a nice amount to aim for. Don't overlook used "pro" amps; they generally give you more watts per buck than a plate amp. Keep your eyes open at thrift stores, pawn shops and yard sales, if you can be patient. Or watch eBay for auctions near you; shipping costs may deter people from bidding.
Greetings and a couple of questions Sasquatch Tubes / Valves 18 10th February 2007 08:49 PM
couple of questions slogan2112 Multi-Way 0 27th June 2004 08:38 PM
a couple questions slackerbob Solid State 1 12th August 2003 02:25 AM
Page generated in 0.10362 seconds (67.63% PHP - 32.37% MySQL) with 10 queries
