Box design for Eminence Omega Pro 18C - Page 2 - diyAudio
Old 27th September 2008, 04:37 AM   #11
MJL21193's Avatar
And the driver excursion for the above.
Old 27th September 2008, 06:21 AM   #12
dangus is offline dangus  Canada
If you've got good recordings of the band, play them through a real-time analyzer and see just what frequencies are there. No sense paying for sub capabilities that aren't needed.
Take a look at some horn designs as well. Having a chest-crushing kick drum may outweigh the lack of wubba wubba infrabass when it comes to pleasing the crowd.
Old 28th September 2008, 01:56 AM   #13
GM is online now GM  United States
GM's Avatar
Originally posted by ted01
More box volume = lower freq. but with less power. So if I want to get down low, I need a big box, but can't shoot lots of power to it.
Right you are. Here's a simple tapped pipe (6th order BP) half space sim with ~30 W input to hit Xmax @ 20, 33 Hz, but it's ~411 L net:
Unfolded length = 333.5 cm/131.3"
w x d = 1232 cm^2/190.96"^2
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th September 2008, 01:15 AM   #14
pjpoes is offline pjpoes  United States
Send a message via AIM to pjpoes
well whats been said about xmax is still very important to consider. I wouldn't say that xmax is the only determining factor in spl, some modern woofers have more xmax than power handeling (TC sounds and Adire were often that way), but in the Pro driver world, its mostly true. Unfortunately the driver you have simply is not a good subwoofer driver, regardless of the enclosure used. While some designs will do a better job controlling xmax at the lower frequencies (ported, TL, and horn), none will be able to control it enough to be truly usable as a subwoofer at 25hz. An examination of that drivers xmax across frequency shows a massive increase well beyond its limits at far too high a frequency. Adding mass to the cone helps, but you then have some issues with a loss of efficiency. If you are unwilling to consider selling those drivers and trying something else, then you will have to accept that you will not have very great output in the sub bass range of 20-30hz.
FS: Eminence Omega Pro-15A truenorth Swap Meet 0 29th April 2009 01:53 AM
Subwoofer Pro Eminence Omega 18 (EPS18-600)??? goodspeaker Subwoofers 6 7th July 2006 12:44 AM
Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application esaias Subwoofers 8 10th August 2005 06:17 AM
Best Tweeter for OMEGA PRO 15 ganzonimx Multi-Way 2 29th January 2004 10:46 PM
Eminence Omega p-12A Duo Multi-Way 9 9th January 2003 06:02 PM
Copyright 1999-2017 diyAudio
