Old 19th September 2008, 07:10 PM   #1
Default cheap sub driver in europe..
hi all :-) I have been modelling a sub as a gift with a tang band w69-1042.. now i figure that if i am going to the trouble to construbt a cab, paint it and put quite a lot of effort in then the driver is the definate weak point.. in a 20l cab I can only get down to 40hz with a 15inch x 3" pipe and even then if i take the plate amp (mivoc am 80) near to it's capaity i reach xmax..
to that end can anyone recomend a decent driver available to the uk for about £20ish.
maybe from http://www.lautsprechershop.de/hifi/index_en.htm
i would go with partsexpress but shipping and import duties are prohibative.
thanks all.
Old 19th September 2008, 07:31 PM   #2
Not exactly within budget, but I ordered the Monacor SPH 212 from that supplier, and with a Detonation 50 plate amp it is a good match in a 30-something liter BR enclosure.
Very good and correct service, but then again, they are Germans so that's why they are so efficient.
I would now aim for a minimally rising slope of about -4db down at 30Hz and 0dB down around 80Hz. This should extend - depending on your bassport tuning - the response to 25Hz flat in-room, where the Detonation 50 amp's rumble filter kicks in.
Less group delay, less port shuffing and slightly larger output in the lower freq. About 95-100dB output should be possible.
-- If in doubt: overdesign!
Old 19th September 2008, 07:54 PM   #3
I already have the mivoc am80 that has a -3db at 30hz so should be good. I will check it out.
edit - just looked at that and according to the specs it doesn't look any better than the tang band..
Old 19th September 2008, 10:00 PM   #4
OK, I just looked at the 40Hz so that is why I thought a driver with 30Hz would be better.
Oh well ...
driver suppliers austria/europe chainenoble Multi-Way 1 29th December 2006 07:40 AM
Europe cheap capacitor ????where TJ Parts 17 22nd September 2006 08:52 AM
cheap OSCON's/Blackgate's ind Europe ? weissi Parts 0 31st July 2006 09:08 AM
Hammond 125ese cheap in Europe? John007 Tubes / Valves 10 4th March 2004 09:18 PM
cheap subwoofer in europe then_dude Subwoofers 2 1st March 2004 08:06 PM
Page generated in 0.11787 seconds (71.97% PHP - 28.03% MySQL) with 10 queries
