2x12" Alpine Type-R box
Old 29th September 2008, 05:15 PM   #21
GM is offline GM  United States
GM's Avatar
Series VCs:
File Type: gif alpine swr-1221d 13.5-135 hz th (series vc) - specs.gif (13.9 KB, 220 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th September 2008, 07:01 PM   #22
defwing is offline defwing  New Zealand
Thanks for those inputs, they helped me considerably and pointed out my errors.
I have come up with the specifications and have designed the box on paper/hard drive. To fit in with the cabinet design(something special) it had to change a little and I am sure it will change again slightly while building it too
Thanks for your help and I will post pictures when it is done.
Also, sorry to hijack the original thread.
Old 5th October 2008, 06:09 PM   #23
MattODoom is offline MattODoom  United States
Send a message via AIM to MattODoom
Can I get some opinions from people who actually know how to calculate speaker output (unlike me!), I'm wondering if dumping this 2x 12" Type-R setup and replacing it with one 15" Dayton either Reference or Titanic would put out more SPL? Also, how would the responses compare.
Old 5th October 2008, 10:01 PM   #24
TravisDigital is offline TravisDigital  United States
Default calculating output
Calculating speaker output is called a decibel log. dB logs are simple. Let's say the speaker's sensitivity is 93dB@1w/1m, and you have a true 600w of power for this one speaker. every time you double your power starting a 1 watt, you gain 3dB. so 2w=96dB, 4w=99dB, 8w=102dB, 16w=105dB, 32w=108dB, 64w=111dB, 128=114dB, 256w=117dB, 512w=120dB=hearing damage, and the extra 88w that were not added in might gain you 1dB. If you have 2 speakers you add 6dB every time you double power.
In my personal opinion I would go with 1 15" over 2 12" due to the lower frequencies the 15" can produce, and most of the time will achieve higher SPL levels as well.
Old 5th October 2008, 10:17 PM   #25
technofreak is offline technofreak  Estonia
technofreak's Avatar
Send a message via MSN to technofreak
Default Re: calculating output
That's right, but you also have to consider power compression - more current = higher voice coil temperature = higher resistance = less power (P=Iˇ2/R). Typically power compression at full power is approx. 3...6 dB.
Old 6th October 2008, 12:35 AM   #26
Default Re: Re: calculating output
Originally posted by technofreak
That's right, but you also have to consider power compression - more current = higher voice coil temperature = higher resistance = less power (P=IÇ2/R). Typically power compression at full power is approx. 3...6 dB.
yup... you got me, I forgot all about thermal compression. Thanks for posting the formula (p=IC2/R)
Old 29th December 2013, 12:53 AM   #27
motomark73 is offline motomark73  United States
Default paging GM
I'm sorry to resurrect a dead thread but I have a 12" alpine type r from same vintage as this thread and a 500 watt plate amp. I have been strongly considering coupling the 2 together in a horn. I have been following the lilmike builds. Specifically the lilwrecker but built scaled down width for a 12 vs 15. It was referenced as a T12 at times. Curious if anyone built this.
Old 29th December 2013, 06:05 PM   #28
littlemike is offline littlemike  United States
lilmike here, just have a different user name on this forum.
I never finished the T-12 fold for a number of reasons, the main one being that I wound up with some 15" drivers that I've been working with.
The Alpine Type R 12s I have worked with perform very well. My experience was that they want a larger cabinet, and they want a low tune. I don't have any on hand to work with at the moment, and don't have a lot of free time either.
Old 29th December 2013, 10:42 PM   #29
Thanks for the reply... I will teach myself hornresp and see what I can come up with. Good knowing that I have pieces that are worth putting together in a tapped horn. Thanks for the response. Hope your time frees up, but you've done a ton of work for the diy community. Rest assured that for every 1 person you reply to, there are another 25-30 people reading and learning. Thanks for all your efforts in removing some of the mysticism of horns. It was not an alignment I would previously have considered without reading your many posts on the subject.
2x12" Alpine Type-R boxHide this!Advertise here!
Alpine Type S is your Value Leader. Patrick Bateman Subwoofers 35 20th January 2014 08:03 AM
New Alpine Type R Speakers just sound ok - not sure why brownsfan019 Car Audio 2 29th May 2013 06:35 PM
2x12" box design Computerdude Subwoofers 6 5th January 2012 01:36 PM
Alpine Type X clipping mikaelfred Subwoofers 2 5th August 2008 06:02 PM
Copyright ©1999-2017 diyAudio
