Old 13th September 2008, 06:41 PM   #1
Send a message via AIM to Chris8sirhC
Default 6th order bandpass
I have been going through every possible option to try to use up these 16 10's that I have lying around (TL, dipole, Lin transform, etc). I came up with a 6th order bandpass that looks good from 50hz to 130hz or so. I am looking to cover from 50hz up to 150hz if possible. I also want it to be as small as possible. Here are the paramaters:
Re 7.20 [ê ]
Fs 44.26 [Hz]
F1 35.48 [Hz]
F2 56.23 [Hz]
Zm 53.74 [ê]
D 208.00 [mm]
Qms 5.80
Qes 0.90
Qts 0.78
Bl 6.76 [N/A]
L1K 1.47 [mH]
L10K 0.72 [mH]
Ms 20.47 [g]
Vas 101.85 [l]
dBSpl 92.34 [dB]
Cms 0.63 [mm/N]
Ma 48.00 [g]
FsMa 24.20 [Hz]
The box i came up with in WinISD is as follows (2 drivers in a clamshell IsoBaric):
rear volume 1.541 ft^3
rear freq 41.54hz
rear port length 3.73in dia= 2.68in
front volume 0.925 cubic feet
front freq 93.72
front port length 1.25in dia = 4.02 inches
at max power (60 watts) I am getting about 112db
I have never made this type of design before. Anybody that has experience with bandpass, what do you think of this design. Could I make it smaller and still cover down to 50hz? I plan on using at least 4 of them in a room ala gedlee, but I will be able to build up to 8 of these things.
Old 13th September 2008, 07:09 PM   #2
Is the group delay always 2-3x worse than a lin transform design?
6th Order Bandpass HT Sub, would like some feedback pjpoes Subwoofers 2 3rd September 2008 01:55 AM
4th Order Bandpass Help berserker Subwoofers 9 19th January 2007 03:56 PM
4th order bandpass with PR tade Subwoofers 2 14th November 2005 01:08 PM
4th order bandpass 4 way the phantom Multi-Way 3 27th July 2005 06:28 AM
6th-order Bandpass BAM Subwoofers 1 24th September 2001 05:51 PM
Page generated in 0.08803 seconds (70.43% PHP - 29.57% MySQL) with 10 queries
