Old 28th September 2008, 08:44 PM   #41
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
Looking at the schematic for the amp, it does indeed have +/- 15v rails, so it would be an ideal match for the filter circuit.
Not only do you save on a separate power supply which can introduce hum if not implimented well, but you get the option of mounting the filter inside the sub for a seamless installation.
I have one of those amps myself, but never had the circuit, so this exercise truly has been a 2-way street!
As for using the TL072/LF353N op-amps, I'm no expert. I know Rod Elliot uses the TL072 in his filters, and he's an Aussie circuit guru, so I think it would be fine. Someone else might be able to confirm that though!
Ports rule!
Old 29th September 2008, 12:57 AM   #42
djk is offline djk
djk's Avatar
This should be obvious.
The ESP filter has an input buffer, two 12dB filter sections, and an output buffer.
The plate amp has an input buffer, one 12dB filter section (C13, C14, R23, R24), and a second 12dB filter section C1, R1, R2, and add a resistor from the connection point of C1, R1 to the base of Q2, the power amp is the output buffer.
C1 will now be the same as C13, change R1 to the same as C14, the added resistor is R23, R2 is R24.
Now we have the same functions as the ESP filter with no extra board, opamps, etc.
Candidates for the Darwin Award should not read this author.
Old 30th September 2008, 12:00 AM   #43
otto88's Avatar
Thanks for the link http://www.subwoofer-builder.com/active-filter.htm to your excellent guide to 0.1 filters 101
Your wish list for the ideal subwoofer processor is good.
If I could suggest a wish for formula on LR HP filters, which calculates the component values. As well as 24 dB/octave, a formula for 36 dB/octave.
That’s also really good that WinISD models the changes to cone excursion and frequency response. Though I’ll wait till their next production release!
Cheers
48db/oct Subsonic filter Iván Francisco Solid State 4 28th December 2007 04:57 PM
subsonic filter from 25hz - 0hz djronbxs Solid State 0 27th November 2007 06:43 AM
Hypex 400watt plate amp w/ 17hz subsonic filter. For SALE! mp006ltk Swap Meet 1 15th November 2006 02:58 PM
Subsonic filter bybass? jakelm3075 Subwoofers 14 16th March 2006 01:55 PM
DIY subsonic filter anyone? BobM Analogue Source 4 25th August 2003 05:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
