Old 8th September 2008, 09:47 PM   #1
FlipC is offline FlipC  United States
Default Horn segmenting questions
So I know the trick of figuring out the wave length and then folding that upon itself to figure out the fold pattern but what about the degree of angles to which those folds should be?
Or is it with above to where I have
a straight horn that's mouth it X area so when I bend it that is the degree of angle I get?
Also should it always be expanding?
Old 8th September 2008, 10:35 PM   #2
GM is offline GM  United States
GM's Avatar
Right, always expanding.
For 'sub' duty the WLs are so long it doesn't matter about the angle. This is only a consideration when you're trying to eek out the max acoustic gain and/or HF BW from one.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th September 2008, 11:09 PM   #3
Cool
Vague horn questions bigwill Multi-Way 7 21st December 2007 07:02 PM
horn questions e-side Multi-Way 39 22nd August 2005 08:39 PM
Horn questions slackerbob Subwoofers 11 1st August 2005 10:31 PM
A some horn questions mashaffer Multi-Way 3 19th May 2005 02:58 PM
Fostex 103 horn questions GrahamnDodder Full Range 12 2nd March 2004 06:53 AM
Page generated in 0.08700 seconds (60.94% PHP - 39.06% MySQL) with 10 queries
