The Smallest Tapped Horn - Page 8 - diyAudio
Old 15th May 2009, 08:55 PM   #71
Odd - the link I posted works for me when I test it.
GM - your link does not work for me in Firefox, but does work in Internet Explorer.
Sorry for the confusion.
Old 15th May 2009, 10:35 PM   #72
GM is offline GM  United States
GM's Avatar
Interesting! I wonder why, especially since I'm running Mozilla Firefox also. Yours I get an error message and of course my link works for me in Firefox, but both mine and yours works in IE. This really makes no sense to me.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th May 2009, 11:32 PM   #73
Patrick Bateman's Avatar
Here's some pics of the boxes. I noticed in the diagram I forgot to include the height of the mouth! It's sixteen inches tall. The first box is 13.5" wide, the second is 9.5" wide.
The simulation for the P-Audio is based on a width of 12", but then I noticed the frame is 12.25". Shouldn't make a big difference in the response...
Old 17th May 2009, 07:36 PM   #74
Based on a discussion here, I threw together a pic of what this box would sound like if I didn't use a flare at the mouth.
The idea is that using a significant flare at the mouth flattens the response, while raising the F3. Since this box will likely end up in a car, a low F3 is actually a bad thing (due to cabin gain.)
Flatter response and a small box are definitely what we're after here.
Old 20th May 2009, 04:39 AM   #75
So I'm building two boxes. One for a single twelve, and one for dual eights. Just to cover my bases, I created an Akabak script to model a tapped horn with dual woofers. (Horn response models them as if they're radiating from the same point in space; it doesn't account for the gap between them.)
I was a bit surprised to see that the efficiency nearly doubles, and 3rd harmonic distortion is reduced too!
Talk about a free lunch
Here's a pic of the response; note it's more efficient from 60-150hz, and *less* efficient from 250hz on up (where the distortion is.)
Niiiiiice....
The graph looks a little weird because I use a photo editor to merge the two simulations (I don't think there's a way to compare two designs in Akabak or Hornresp.)
Old 20th May 2009, 04:44 AM   #76
Here's an Akabak model for a tapped horn with dual woofers.
It's a bit confusing; let me know if it's hard to figure out where the taps are. I included a diagram.
System 'S1'
|DATA EXPORTED FROM HORNRESP - RESONANCES NOT MASKED
|COMMENT: th-mini clone, xara file is on other pc, 5/10/09. This one w/MCM 55-2421x2
|REQUIRED AKABAK SETTINGS:
|File > Preferences > Physical system constants:
|Sound velocity c = 344m/s
|Medium density rho = 1.205kg/m3
|Sum > Acoustic power:
|Frequency range = 10Hz to 20kHz
|Points = 533
|Input voltage = 31.62V rms
|Integration = 2Pi-sr
|Integration steps = 1 degree ... 1 degree
|Integration method = Cross
Def_Const |Hornresp Input Parameter Values
|Length, area and volume values converted to metres, square metres and cubic metres:
Rg = 0.01e-0; |Amplifier output resistance (ohms)
S1 = 54.83e-4; |Horn segment 1 throat area (sq cm)
S2 = 70.00e-4; |Horn segment 1 mouth area and horn segment 2 throat area (sq cm)
S3 = 90.00e-4; |Horn segment 2 mouth area and horn segment 3 throat area (sq cm)
S4 = 387.00e-4; |Horn segment 3 mouth area and horn segment 4 throat area (sq cm)
S5 = 604.40e-4; |Horn segment 4 mouth area and horn segment 5 throat area (sq cm)
S6 = 1401.30e-4; |Horn segment 5 mouth area and horn segment 6 throat area (sq cm)
S7 = 1836.00e-4; |Horn segment 6 mouth area (sq cm)
L12 = 25.64e-2; |Horn segment 1 axial length (cm)
L23 = 30.00e-2; |Horn segment 2 axial length (cm)
L34 = 170.00e-2; |Horn segment 3 axial length (cm)
L45 = 11.00e-2; |Horn segment 4 axial length (cm)
L56 = 40.60e-2; |Horn segment 5 axial length (cm)
L67 = 22.10e-2; |Horn segment 6 axial length (cm)
|Parameter Conversions:
Sd = 440.00e-4; |Total diaphragm area for 2 parallel drivers (sq cm)
|Network node numbers for this tapped horn system:
|0-Voltage-1-Resistance-2----------
| x x
| --Driver1------ ---------------------------
| x -Driver2-------------- x
| x x x x
| 8-Segment-9-Segment-10-Segment-11-Segment-12-Segment-13-Segment-14-Radiator
Def_Driver 'Driver'
Sd=220.00cm2
Bl=14.56Tm
Cms=3.48E-04m/N
Rms=1.20Ns/m
fs=31.0000Hz |Mmd = 73.86g not recognised by AkAbak, fs calculated and used instead
Le=2.42mH
Re=3.40ohm
ExpoLe=1
System 'System'
Resistor 'Amplifier Rg'
Node=1=2
R={Rg}
Driver Def='Driver''Driver 11'
Node=2=0=9=12
Driver Def='Driver''Driver 21'
Node=2=0=10=13
Waveguide 'Horn segment 1'
Node=8=9
STh={S1}
SMo={S2}
Len={L12}
Conical
Waveguide 'Horn segment 2'
Node=9=10
STh={S2}
SMo={S3}
Len={L23}
Conical
Waveguide 'Horn segment 3'
Node=10=11
STh={S3}
SMo={S4}
Len={L34}
Conical
Waveguide 'Horn segment 4'
Node=11=12
STh={S4}
SMo={S5}
Len={L45}
Conical
Waveguide 'Horn segment 5'
Node=12=13
STh={S5}
SMo={S6}
Len={L56}
Conical
Waveguide 'Horn segment 6'
Node=13=14
STh={S6}
SMo={S7}
Len={L67}
Conical
Radiator 'Horn mouth'
Node=14
SD={S7}
Old 20th May 2009, 06:39 AM   #77
I cranked out a model for four woofers, and now the first peak is completely gone! This really widens the bandwidth in a huge way.
Old 20th May 2009, 06:10 PM   #78
Hmm. You seems to have connected the drivers wrong.
The first driver needs to be first and last.
The second in the middle (as you fold around)
Unless you have some strange folding.
Node=2=0=9=12
Node=2=0=10=13
vs
Node=2=0=9=13
Node=2=0=10=12
Might be wrong though.
I can't see much benefit now.
Impulse response is smeared out due to additional peaks from drivers.
Not sure if it matters at LF though.
I will have to do further testing as I just finished my own model.
Old 20th May 2009, 06:57 PM   #79
MikeHunt79's Avatar
Originally posted by Patrick Bateman
Amplifiers are ridiculously cheap, and it would be fun to have a boomin' system in the car. I cloned an autotuba a few years back and fed it with an 800 watt amp, that was a lot of fun until I got sick of the sheer size of the box.
If you don't mind me asking, what do you have in your car now?
I currently have a dual driver autotuba in mine, and while is sounds great, it is a little large as it fills my entire boot (trunk)!
I was wondering if there is something similar which is smaller yet gives the same rising response of the AT?
I was thinking maybe a TH tuned to 60Hz, maybe with a 8" MCM but maybe a 12" driver would work better?
Old 20th May 2009, 07:15 PM   #80
Node=2=0=9=12
Node=2=0=10=13
vs
Node=2=0=9=13
Node=2=0=10=12
You are correct - I didn't catch this until I made the four woofer model, and the response was really bizarre until I fixed it.
Before I built a tapped horn, I was worried that they'd have issues in the time domain. But I haven't noticed any subjectively. Once you get used to the lack of distortion, sealed subs start to sound kinda weird.
Tapped Horn for Dummies Patrick Bateman Subwoofers 249 3rd June 2012 08:10 PM
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 10:22 AM
tapped horn wiki? weikertball Subwoofers 0 31st May 2008 05:20 PM
Copyright 1999-2017 diyAudio
