Old 4th September 2008, 10:41 AM   #11
MaVo is offline MaVo  Germany
Hi Patrick, you can make a TH with a mouthsize of about 1 * SD with good response. The simulation shows a Beyma 12P1000ND in a 60Liter tapped horn. Doubling the mouthsize gives you additional 3db maxspl.
Old 4th September 2008, 12:02 PM   #12
djk is offline djk
djk's Avatar
This is about an inch taller, and a couple of inches deeper. Kicks severe butt. A JBL2206 will also work in the same box.
Candidates for the Darwin Award should not read this author.
Old 4th September 2008, 01:53 PM   #13
djk is offline djk
djk's Avatar
Mid-Bass / L12P540
• high power 12" mid-bass
• very good power handling, excellent linearity and very low distortion
• diameter: 12"
• impedance: 8 Ů
• power: 400W rms, 800W program
• spl: 97 dB
• frequency range: 50 Hz–2 kHz
• voice coil: 3" copper
• baffle cutout: 11.2"
• depth: 6.1"
• weight: 18.7 lbs
Old 6th September 2008, 10:41 AM   #14
djk is offline djk
djk's Avatar
| 50 Hz Tapped Horn
Def_Const |Horn Dimensions
a1 = 150e-4; |Area at throat (cm^2)
a2 = 250e-4; |Area at rear of driver (cm^2)
a3 = 1100e-4; |Area at front of driver (cm^2)
a4 = 1200e-4; |Area at mouth (cm^2)
l1 = 15e-2; |Distance from throat to rear of driver (cm)
l2 = 178e-2; |Line distance from rear of driver to front of driver (cm)
l3 = 25e-2; |Distance from front of driver to mouth (cm)
Def_Driver 'Dr1'
| RCF L12P540
Sd=530cm2
fs=59Hz
Qes=0.36
Qms=11
Vas=45L
Re=5.6ohm
Le=1.8mH
system 'S1'
Driver Def='Dr1' Node=1=0=3=4
Waveguide 'W1' Node=2=3 STh={a1} SMo={a2} Len={l1} Conical
Waveguide 'W2' Node=3=4 STh={a2} SMo={a3} Len={l2} Conical
Horn 'H1' Node=4 STh={a3} SMo={a4} Len={l3} Conical
Old 7th September 2008, 09:44 AM   #15
FlipC is offline FlipC  United States
Still cant get my head around Hornresp.
Driver specs:
Power handling: 600 watts rms
Voice coil diameter: 2"
Voice coil inductance: 1.81 mH
Impedance: 4 ohm
DC resistance: 2.60 ohms
Frequency range: 20-450 Hz
Magnet weight: 112 oz.
Fs: 18.8 Hz
SPL: 90 dB 1W/1m, 93.4 dB @ 2.83V/1m
Vas: 232.2.
Qms: 8.66
Qes: .39
Qts: .38
Xmax: 15.1mm
Re: 2.8
Le: 1.82
Mms: 297.1
CMs: 0.24
Sd:829.6
Vd:1252.7
BL: 16
Trying to put this into a box of roughly 104.5 L
I don't understand how to get some of HRs measurements. Like Rms and Mmd. I also haven't figured out how to define box parameters. Layout equals a 13 foot horn length (roughly) within the space of 7 folds. 13 foot would (roughly) get me the 1/4 wave length for 50Hz ?
Help a laymen comprehend?
Old 7th September 2008, 10:06 AM   #16
djk is offline djk
djk's Avatar
"Trying to put this into a box of roughly 104.5 L"
The driver you listed is not suitable for a 50hz tapped horn.
"I don't understand how to get some of HRs measurements. Like Rms and Mmd. I also haven't figured out how to define box parameters. "
You don't have to understand them, just enter as required. The 'HELP' section tells you how to do this. The program calculates what it needs from common T/S parameters.
"Layout equals a 13 foot horn length (roughly) within the space of 7 folds. 13 foot would (roughly) get me the 1/4 wave length for 50Hz ?"
The speed of sound is roughly 1130 ft/sec, the 1/4W of 50hz is thus 5.65 ft, or 67.8 inches.
As you can see from my 50hz AkAbak script, the main horn length is 1.78m, or about 70 inches.
Old 7th September 2008, 10:18 AM   #17
Patrick Bateman's Avatar
As DJK alluded to, that's one of the great benefits of a tapped horn. It doesn't require a "typical" subwoofer driver, where the FS is very low, nor a "typical" horn driver, where QTS is very low.
Old 7th September 2008, 09:06 PM   #18
GM is offline GM  United States
GM's Avatar
Originally posted by FlipC
Driver specs:
What make/model is this?
BTW, you didn't say what the XO point is, so don't know how much BW you want to try and get out of it.
As already noted, this is a very poor choice for a 50 Hz TH, especially in ~104.5 L due to its high Vas, but curiosity got the best of me to see how poor a choice it is:
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th September 2008, 09:41 PM   #19
After what I learned on my Tapped Horn for Dummies thread, I realized that the best driver for a 50hz horn would have an FS in the range of 60-100hz.
Old 8th September 2008, 12:06 AM   #20
djk is offline djk
djk's Avatar
Right you are.
RCF L12P540
Sd=530cm2
fs=59Hz
Qes=0.36
Qms=11
Vas=45L
Re=5.6ohm
Le=1.8mH
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 11:22 AM
Tapped Horn for Dummies Patrick Bateman Subwoofers 248 26th April 2011 05:31 AM
tapped horn wiki? weikertball Subwoofers 0 31st May 2008 06:20 PM
Page generated in 0.12625 seconds (81.40% PHP - 18.60% MySQL) with 11 queries
Copyright Š1999-2012 diyAudio
