Old 16th June 2009, 03:54 AM   #101
Patrick Bateman's Avatar
A few days ago I posted the measured response inside my car. (Which is where I'll use it.)
Here's the measured response outside:
The orange and the red graphs are the tapped horn. I took two measurements, at equal distances, to isolate high frequency peaks.
Note the SPL levels aren't calibrated whatsoever; I just crank up the volume to get plenty of clean signal.
For comparison's sake, the blue lines are my old sub, which is a transmission line that uses dual 12" woofers.
The interesting part is that they're practically identical below 50hz! Hoffman's Iron Law at work
The transmission line uses dual woofers, and is built LIKE A TANK. In addition to the serpentine construction, it also has cross braces and it's metal plated!
The pic shows three of my subs. The old transmission line, the new tapped horn, and my bandpass subwoofer from my home theater.
The tapped horn is basically an unqualified success. It's more efficient, uses one woofer instead of two, is easier to build, and weighs less than HALF as much. The TL is 73lbs, the TH is 35lbs. The bandpass clocks in at a svelte 28lbs, thanks to it's sonotube construction
Tapped Horn for Dummies
Old 16th June 2009, 05:31 PM   #102
Originally posted by sumsound
Same the B&C 12PS100-
I did add~ 5mH of inductance
Am I close with the internals??
Hi sumsound,
why did you add 5mH of inductance?
Old 17th June 2009, 02:47 AM   #103
mwmkravchenko's Avatar
Default Just a heads up
Hi Patrick
You inspred me to see how small I could get a tapped horn. As well as a tapped horn that worked with cabin gain and gave you a semi-flat response all the way down to 18hz.
http://www.diyaudio.com/forums/showt...32#post1856932
Mark
Mark
Old 5th July 2009, 03:23 AM   #104
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Hey Patrick thanks for letting us know about the 8" MCM driver it really does model exceptionally well in a TH. It outshines the 6" Tang Band I was looking at and is about $15 cheaper! It will be my next Sub project.
PASSIONN
Old 21st August 2009, 02:53 AM   #105
Originally Posted by brsanko View Post
well here it is tapped horn for TB 6.5" sub. System Volume about 30 liters. Response down to 30Hz. Volume above 120db.
You've modelled it for 0.5*PI space. Model it for 2*PI space to get figures that are more comparable to those produced by box modellers for sealed / vented systems.
Old 21st August 2009, 04:46 AM   #106
winslow is offline winslow  United States
Wonders if my JBL 2204Hs would be worth a shot in a TH in the car?
In case you missed it on DIYMA, can the TH for the car play realistic sub-bass levels?
Old 22nd September 2009, 06:37 AM   #107
Based on the research that I've done, the smoothest response and widest bandwidth is to be found when you use an array of small high excursion woofers.
The array spreads out the resonances, reducing the peaks and dips inherent in the tapped horn design. It allows us to use a box size that's incredibly small.
Old 22nd September 2009, 06:40 AM   #108
I had a hunch that Danley is using multiple woofers in his new tapped horns to smooth the peaks and the dips that appear when you use a horn that's too small.
The results of my experiment can be reviewed here:
http://www.diymobileaudio.com/forum/...tml#post837001
Here's the measured response of a tapped horn using three $25 woofers from MCM, with smoothing applied:
Pretty darn smooth, if I do say so myself...
Old 22nd September 2009, 12:11 PM   #109
It would be, if you apply smoothing
Old 22nd September 2009, 12:33 PM   #110
Hi Patrick
Are you using ARTA to do your measurements? Kind of looks familiar to ARTA anyway.
Industry standard smoothing is 1/3 octave by the way.
Nice application of design sleuthing.
Mark
Mark
Tapped Horn For Car mwmkravchenko Subwoofers 365 17th November 2011 11:22 AM
Tapped Horn for Dummies Patrick Bateman Subwoofers 248 26th April 2011 05:31 AM
tapped horn wiki? weikertball Subwoofers 0 31st May 2008 06:20 PM
Page generated in 0.14547 seconds (69.93% PHP - 30.07% MySQL) with 11 queries
