Old 2nd September 2008, 03:18 PM   #1
hm is offline hm  Europe
hm's Avatar
Default mini double bass horn
Hello Members,
i check something out,
opinions?
A small double bass horn
size 15 x 65 x 70 cm
2,5 + 3,5 m horn down to ~30 Hz
extrem variable to use as an Armchair, double seater, writing table,
big spanish wall, wall sub or sat stand place.
http://www.hm-moreart.de
Old 2nd September 2008, 03:51 PM   #2
Horst,
which driver?
What is the upper limit / cutoff?
SPL?
Plans?
Will it work with Schalmei Sat?
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 2nd September 2008, 04:18 PM   #3
hm's Avatar
Default Hi Andrew
http://www.mivoc.com/mivoc/PDF/WAL416-Datenblatt.pdf
measurement are not made, takes a few weeks.
May be you need 4 each canel
Old 14th September 2008, 08:20 AM   #4
hm's Avatar
Default measurements
measurements are made:
12 dB - 15 mH + 220 µF
nice IMP no crossover
double horn, bib or angular spiral horn? testarossa2k Full Range 49 18th September 2011 03:03 PM
mini bass horn hm Subwoofers 7 7th April 2008 06:14 PM
double Horn for FE167 Spassgeneral Full Range 29 20th February 2008 07:37 AM
Kornett double horn hm Full Range 1 4th January 2008 03:20 PM
double horn 108 ? brad212 Full Range 12 31st March 2005 08:07 PM
Page generated in 0.10854 seconds (56.38% PHP - 43.62% MySQL) with 10 queries
