Is this a TH?
If I understand what you're saying, I don't think so.
A TH loads both sides of the driver into the horn path. One side of the driver enters the horn near the throat end, the other side near the mouth end. The back chambers on the WO/WO32 appear to be sealed, regardless of the direction of the woofer. Flipping the woofers still has one side loaded into a sealed box, not the horn path.
Mounting the woofers in the mouth would be a start towards a tapped horn, but you'd still need to sort out an appropriate path internally.
