Hi all, was just looking at my old Longmill 10" car woofer, and I ask myself, the magnet is vented, I can see a gauze, but the cone and dust cap are sealed. Is this right? What would happen if I put a hole in the dustcap? Reason I ask, is because of pressure relief in a Sealed Enclosure, is there a benefit?
Mike
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi |
#2 |
Speakerholic
I think you'll find you vent one or the other or you'd have a "hole" in the cabinet right through the driver. It would probably make a lot of chuffing noise at higher levels as the driver moved in and out. You might also have cancellation issues, although in todays world of OB that seems trivial.
#3 |
Did it Himself
If the dust cap was holed as well there would be no pumping action. As well as the cabinet having an effective hole in it.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
wouldn't it be creating a virtual port as well. It's tuning would vary depending the on the vent dimensions in the magnet and size of the hole, but lets say you removed the dust cap, the voice coil is say 2", that might mean say a 2" by 6" port. In a 1 cubic foot box that might be a roughly 35z tuning. My point would be, its no longer a sealed box but would instead would perform like a ported sub with an undersized port (i.e. probably chuffing at higher volumes).
Now if you mean just putting a tiny hole, say a 1/4" hole in the dust cap, which is what I suspect you are talking about, it still would be acting like a port in a way, but with a much different tuning, and because of the very tiny size, and the air going from the larger coil volume into the dustcap "chamber" and out that tiny hole, would have very bad chuffing, I would think. None the less, many speakers are not well sealed, especially in the proaudio world, where they are generally used in a ported, bandpass, or horn loaded enclosure, and where it won't matter as much. |
#5 |
I figured something like that. I read somewhere that, if you put a hole in the dust cover, it helps with cooling at high power levels. Perhaps it was bad info!
Thanks, again
#6 |
Speakerholic
It was good info. A vented cap will help cool the motor. So does a vented pole piece. You're just not likely to see both on the same driver.
| Interesting results from dust cover upgrade | thoriated | Analogue Source | 1 | 25th August 2009 09:50 PM |
| cutting dust cover off of fostex fe166 | fin1bxn | Full Range | 27 | 9th May 2007 10:47 PM |
| replacing a Pro-ject 1.2 dust cover | stephen Bishop | Analogue Source | 6 | 8th November 2006 10:32 PM |
| dampening noise from magnet vent | Ignite | Subwoofers | 2 | 23rd May 2004 10:06 AM |
| Dust Cover Restoration or Replacement | Michael Rothacher | Analogue Source | 2 | 20th September 2002 08:18 PM |
| Page generated in 0.27664 seconds (25.05% PHP - 74.95% MySQL) with 10 queries |
