Old 24th August 2008, 10:44 AM   #1
RobWells's Avatar
Default When modelling a triple chamber BP do I...?
Just model a 'standard' 6th order BP with 2 drivers, then use the front chambers volume and port. With the rear chamber tune with 2 ports, divide its volume by 2 and use 1 port per chamber.
Is it that simple or am I missing something ?
Rob.
Images borrowed from the12volt.com
Old 24th August 2008, 03:12 PM   #2
MaVo is offline MaVo  Germany
My guess is, that both boxes on the pic will be equal, if you get the chamber and port sizes right. Apart from this, i cant rly help you.
Old 24th August 2008, 07:42 PM   #3
I'll second that.
Regards Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 24th August 2008, 07:48 PM   #4
RobWells's Avatar
Well I'm asking about modelling them. I know they'll be pretty equal in output, I just want to mount the drivers push push and need to know if what I said in the first post was correct ?
Rob.
Old 25th August 2008, 05:49 AM   #5
GM is offline GM  United States
GM's Avatar
Default Re: When modelling a triple chamber BP do I...?
Yes.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th August 2008, 08:20 AM   #6
RobWells's Avatar
Thankyou
Quad 303 triple cascade hahfran Solid State 28 12th May 2011 10:48 AM
FS LM3886 Triple monoblock amp chevy2410 Swap Meet 7 8th February 2009 06:08 PM
Triple emmiter follower bogdan_borko Solid State 45 31st December 2008 04:40 AM
Peavey Triple X Rewire! Help! xtjdx Tubes / Valves 1 28th July 2005 01:47 AM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
Page generated in 0.14244 seconds (43.27% PHP - 56.73% MySQL) with 11 queries
