Old 24th August 2008, 09:40 AM   #1
Default Bash or not to Bash?
I have seen Bash plate amps on a few high-end pieces. Can anyone give me some details about them? I was going to try to use one of their 500w plate amps to power a little poject of mine.
Old 24th August 2008, 04:27 PM   #2
Asdonk is offline Asdonk  Netherlands
the SVS use BASH plate amps
or this one
http://www.oaudio.com/500W_SUBAMP.html
Ralf
Old 25th August 2008, 01:41 PM   #3
Send a message via MSN to Wildcard26
I am currently using 2 300S to power my 2 subs. The SF on those I believe is set between 18-20 Hz making them ideal for my application. The run very cool and have alot of power. The one I have are from PE. The 500 W version from PE needs the SF mod since it is set very high; the setting escapes my memory right now. The ones from Oaudio have the neat feature of a single channel PEq on it. I believe the SF in this one is lower and does not require the mod. They are both of the same build with slight variations.
Old 25th August 2008, 07:59 PM   #4
Mikey p is offline Mikey p  Canada
The Parts Express Bash 500 has a factory set subsonic filter at 30 hz and it can be modified. The O-Audio Bash 500 has an adjustable subsonic filter and EQ.
Old 25th August 2008, 10:56 PM   #5
Thanks guys....I think I will be using Bash amps on alot of my projects
FS: Dayton / BASH 500 Sub dsrviola Swap Meet 0 18th April 2008 07:20 AM
BASH subwoofer amp at PE Godzilla Subwoofers 6 13th June 2007 02:05 PM
BASH Plate Amp CARTRulz Subwoofers 6 29th June 2006 05:43 AM
Bash adan888 Class D 6 11th November 2004 05:48 PM
Another Mac vrs windows bash jleaman The Lounge 74 8th July 2004 04:11 PM
Page generated in 0.81838 seconds (8.56% PHP - 91.44% MySQL) with 10 queries
