did anybody has experience with this driver and compared with other drivers with the same size? I want to use this driver for Hifi purposes. Frequenz to 60 Hz. Thanks for your help. Josef http://www.diamondaudio.com/content/view/125/191/ |
#2 |
You might try posting this in the Subwoofer and/or Car audio forums - might get better responses.
Soft Dome |
#3 |
Speakerholic
Moved to woofer section.
#4 |
Hmm, no useful specs in the .pdf, so I guess you will have to buy one and measure/post its specs before anyone will consider helping.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
The T/S parameters for the HP15 are on page 5 of this PDF:
http://www.diamondaudio.com/PDF/curr...nual111207.pdf |
#6 |
Ah! Forgot they might be 'hidden' in the 'support' tab at the top of the screen. Thanks!
GM
#7 |
Well, no experience with this driver, but a ~0.577 Qtc sealed cab of ~5.41 ft^3 (153.2 L) net should in theory work well as would some form of 1/4 WL pipe alignment.
GM
| Diamond Audio D7 7152 | manina | Car Audio | 3 | 27th August 2008 08:01 PM |
| Diamond Audio D6 1500.1 diagram | clayton | Car Audio | 7 | 27th October 2007 03:14 AM |
| diamond audio m561's | favoroldschool | Car Audio | 0 | 16th May 2005 10:28 AM |
| Page generated in 0.08230 seconds (74.99% PHP - 25.01% MySQL) with 10 queries |
