#471 |
The EV T18 specs say: 11.5"W x 24"D x 32.8"H, that's 4 ft^3 gross internal volume minus braces and driver displacement. If you glue two of your T18s together you might get close to the 8 ft^3 you are looking for. Regards,
Oliver |
#472 | |
Your specs are wrong, the T18 is 24.8"W x 24"D x 32.8"H. Big enough to make a decent size BR. |
#473 |
Hi!
So, if ply is 18mm thick, recess of front panel around 4cm for grille, gross volume should be around 252,3liters. Net internal volume = 252.3liters, minus braces, minus driver, minus ducts and we can play with sim program and come out with a good box IMO. The image at post 467 shows refurbished boxes made so. Regards,
PASC |
#474 | |
A few other questions regarding the Stadiumhorn: -will making it 24" wide (external) impair the horn's output much? -will making the bottom rear corner of the enclosure angled (for casters) impair the output much? (I don't think it will - just verifying) |
#475 |
You don't have any lumber supply stores that sell Baltic Birch?? my local Dykes didn't have any in stock, but the Dykes not far away did have plenty of it.... $79 per 5x5x3/4 sheet....
#476 | |
thats only 7 layers instead of 13 layers. make sure you got the right stuff.
one good thing about music ,when it hit you feel no pain. so hit me with music. |
| Dampening in Tapped Horns?? | atilsley | Subwoofers | 25 | 20th June 2009 08:24 AM |
| how to model tapped horns? | weikertball | Subwoofers | 2 | 11th January 2009 09:43 PM |
| tapped horns - a different perspective & an alternative | vasyachkin | Multi-Way | 54 | 14th February 2008 04:25 AM |
| Page generated in 0.08783 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
