Old 10th August 2008, 10:02 PM   #1
HK26147 is offline HK26147  United States
Default Any Exp. w TH using JBL 2206 or 2226?
Has anyone made ( or got ideas ) on Tapped Horns using a JBL 2206 12" or a 2226 15"?
I did a search of this massive forum and didn't find anything
Old 11th August 2008, 05:44 AM   #2
GM is offline GM  United States
GM's Avatar
These were some of the first numbers I ran for TH potential, but didn't publish because no one asked about them AFAIK. Anyway, they are quite large at ~520 L/2206 and ~1054 L/2226, so didn't pursue them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th August 2008, 06:50 AM   #3
djk is offline djk
djk's Avatar
Here is one I posted here earlier for three stacked 2226s for PA:
Here is a very small one for a portable DJ:
The first one is useable to 30hz, the small one 45hz (dance music has its peak output around 55hz).
Candidates for the Darwin Award should not read this author.
Old 12th August 2008, 04:25 PM   #4
First cut through Hornresp - They are big @ 320 Liters+, but 95 dB(-0/+2) into half space @ 2.83 V/1M from 35 Hz to over 100 Hz. There is a pronounced (+5 dB) step in the response above 100 Hz. This is a symmetric design (L12 = L34) so if I fiddle with the design a bit more I might be able to knock that peak down a bit. There does not appear to be an excursion problem.
Old 12th August 2008, 05:52 PM   #5
Thanks All for responses so far.
It looks like no one has built a TH with either of these drivers.
djk: I will keep the 1st sim you listed in mind.
How big is it?
On the 2nd one:
What does very small translate into ( cu ft wise )?
JBL, of course makes no recommendation on usage in horns for either driver, but shows a 2206 in a 4cu ft reflex tuned to 40Hz - I'm guessing approx 95 - 97db 1 watt.
And is that the Max SPl for 3 cabs @ 56.6Vrms?
* I have played w Honresp but not Akabak
Using the 2206, my goal is not max extension but closer to the 45Hz that was listed.
With the 2226 - JBL uses a 10cu. ft. BR tuned to 40Hz.
guessing approx 95 - 97db 1 watt as well.
Mike: I'm assuming that is for the 2226 15", and 11.3 cu ft is only a little bigger than the JBL B/R.
It's it possible to trade a little LF extension for more efficiency at similar or smaller cab vol?.
* A friend has an equal number of 2206 and 2226's.
I wondered if the 2206 by virtue of a stronger BL was a better candidate for horn use than a 2226.
Thxs
Old 12th August 2008, 05:57 PM   #6
Sorry I was not clear, that was the 2206 in that model. I have found that a stronger BL does not always help in a TH.
Have not looked up or entered the specs for the 2226 yet, might be able to get to that tonight - we'll see.
Old 12th August 2008, 06:17 PM   #7
That's OK Mike
I did wonder why a horn cab that big w that 15 would not have greater SPL than it's B/R equivalent.
With a 2206 that cab manages to bring the extension way down below the fs of the 2206 ( at the expense of size ).
I haven't convinced my friend to remove any of these drivers from the existing cabs so I can check T/S parms.
Of course he is from the school of "if a 12" is good, a 15" is better, and an 18" is best"
He does have (2) 2242 18's drivers in B/R cabs, AND the thought of putting those 18's has come up, but I figured ( in error? ), that of those 3 drivers the 2206 was better suited for horn use, and perhaps the 2226 and 2242 were not.
Bear in mind; This is for his band's PA, so the 20 - 40 HZ octave is filtered out anyway.
Old 23rd August 2008, 06:30 AM   #8
Thxs
Yes - it is possible to cut cabinet size considerably if the bottom octave is not needed. SPL picks up a bit too, but shrinking the cabinet cuts the SPL back down (no free lunches).
The 2206 driver in a 3 or 4 segment conical TH that simulates fairly flat from 40-120 Hz, and is capable of 95 dB @ 2.83 V 2 pi has an internal volume of about 185 L (6.6 Cu Ft.) which is significantly smaller. The 2226H takes a little more volume than the 2206, but the design and response remain similar between the two.
Honestly - I am still not sure what drivers are "best" for TH's, so I have no idea as to which (2206 vs 2226) is the better choice. Without details as to the specific driver (G, H, or J) or actual measured T/S parameters, it is hard to say what the best choice is - the design can be tweaked to make either work very well.
Measure, simulate, design, build, measure,......you see where this is going.
Old 23rd August 2008, 07:01 PM   #9
The cab volumes I listed earlier ( From the JBL Professional Enclosure Guide ) was incorrect.
They recommended a 2cu ft cab tuned to 40Hz for the 2206.
They recommended a 4cu ft cab tuned to 40Hz for the 2226.
Since a 2206 produces 95 - 96db in a small BR box, the only way I would consider going to a larger cab box required for a horn is for extra sensitivity above 95 - 96db.
In theory a folded horn 48"H x 24"x ( 13.5 - 18" wide ) should be good for 98db @ 40Hz to 102db @ 100Hz.
But those cabs are 9 cu ft for the 13.5" width and 12cu ft for the 18" width.
In weighing the possibilities for the 2206; I recall the paper:
"An Efficiency Constant Comparison Between Low-Frequency Horns and Direct-Radiators," Presented at the 54th Convention of the Audio Engineering Society, Preprint No. 1127 (M-1), (May 1976).
In which Don Keele detailed the conditions under which B/R boxes ( which don't require the large boxes ) offer a better solution.
In 8 cu ft I can fit 4 2206 in 2 cu ft boxes, the same space as a single driver horn.
In one situation, I am helping a friend convert existing large boxes that house 2 2206. Since the bottom octaves are handled now by 2 JBL 2242 18" drivers, there is no need ( in this case ), for the 2206 to have to be able to achieve 40Hz.
For the 2206, a QB3 box of .93cu ft. gives a 75Hz F3. In that case 8 2206 could fit in 8 cu ft ( approx ) and be hooked in a series/parallel group to yield 4 ohm load (4800 watt rating ) and be fed by a single bridged Crown Macro 2400.
He may opt for this option, as he has the drivers, & the amp, and the cabs build would be straightforward and easy, and modular.
If I had the luxury I would like to compare the folded front horn ( above ) vs a TH of similar size using 2206.
Also I think horn loaded 2206 would work well, for the range from 80Hz to 1Khz.
Thanks Mike
Old 23rd August 2008, 08:46 PM   #10
djk is offline djk
djk's Avatar
"Also I think horn loaded 2206 would work well, for the range from 80Hz to 1Khz."
With a mass corner of about 300hz, it is going to take a lot of boost to make it go to 1Khz.
JBL 2206 crosswover b3keys Multi-Way 1 29th April 2009 07:08 AM
JBL 2206 box size mitchyz250f Multi-Way 8 11th December 2008 01:17 PM
Wtb Jbl 2226 corkster Swap Meet 2 1st February 2008 11:24 AM
811b/806a 16ohm with jbl 2226 or supravox 285 GMF ark Multi-Way 17 30th July 2006 06:17 PM
Keep my JBL 2226 drivers or start over jmiyake Multi-Way 3 13th May 2002 11:23 PM
Page generated in 0.19609 seconds (50.22% PHP - 49.78% MySQL) with 10 queries
