Old 27th March 2009, 02:52 PM   #11
GM is offline GM  United States
GM's Avatar
Originally posted by angeloitacare
How would that be with a conic flare?
any picture or drawing ?
Greets!
Sorry I missed this post and no drawings, but apparently you've either worked it out already or moved on to another type of alignment and now that HornResp has a fairly elaborate slider style Wizard it's a trivial matter to modify my posted expo design to conic and/or another BW within the limits of the driver's specs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 27th March 2009, 03:21 PM   #12
GM's Avatar
Originally posted by N.B.C.
I have a SET/front loaded midbass horn and compression driver based system and, as the saying goes, "it takes a horn to catch a horn".
Down low, I've proven to myself that this isn't true if the XO BW isn't too high, but now that relatively small, inexpensive high power/excursion drivers in THs can compete with large, low tuned TL, MLTL and EBS alignments, might as well build the TH and save the high cost of drivers such as the 1808.
Anyway, if size isn't an issue, then the 1808 should make a fine sub/LF TH and with EQ my expo alignment can be shrunk considerably by using a conic expansion.
Can't comment about the others, but the 416 requires a huge cab also and if the others have a relatively high Vas they will too, so for just a proof-of-concept I recommend buying a small MCM or Tang Band and build a small proven design before committing considerable time/material expense on a huge low tuned alignment.
GM
Old 27th March 2009, 09:20 PM   #13
angeloitacare's Avatar
here the t/s parameters of the Aura 1808
Old 28th March 2009, 05:55 AM   #14
N.B.C. is offline N.B.C.  United States
Thanks Angelo...I have a copy of that.
Thanks for the suggestions GM...but which exponential folding that you made are you referring to?
CBN
Old 28th March 2009, 07:37 AM   #15
GM's Avatar
You're welcome! The sim in post #5.
GM
Dual 8" tapped horn = TH-SPUD geitmans Subwoofers 119 1st January 2012 08:14 PM
10" driver for Bass tower in Horn project angeloitacare Multi-Way 22 29th November 2007 01:10 PM
Another tapped "horn" ? phase_accurate Subwoofers 16 11th August 2007 08:05 AM
18" Folded Bass Horn Design djdan Multi-Way 11 27th October 2003 09:21 AM
Page generated in 0.20815 seconds (31.16% PHP - 68.84% MySQL) with 11 queries
