Old 31st July 2008, 12:12 AM   #1
Send a message via AIM to Kilentra
Default Help - Where to find Sonotube near Boston MA?
Hi all,
I'm teaching a class with high school students and they want to build a cylindrical subwoofer. The design calls for a tube 24" in diameter and 32" high. I've called all sorts of places, and it initially appears that type of tube is unavailable. The problem is that you can get short lengths of the small diameters (i.e. 8" - 12") but larger diameters are only available in 12-foot increments. I was quoted $135 for that length, which is a bit beyond our means.
Yet still I see lots of people have successfully built sonosubs. Where does one buy or salvage short Sonotubes for subwoofer projects (particularly in eastern Massachusetts)? Does anyone have a leftover length from a project?
Michael
Old 31st July 2008, 12:28 AM   #2
kevinkr's Avatar
Try your local home depot and Loews. Also considering redefining the project to use a smaller diameter tube - 24" tube is huge. Most I've seen used much smaller tube.
Others will weigh in soon about this..
How about some ts parameters and the design goals you are trying to meet? This will help those who may want to help.
www.kta-hifi.net
Old 31st July 2008, 01:06 AM   #3
I tried two of the Home Depot stores nearby and their largest diameter is 12". I am guessing this is a pattern. However, I will try Lowe's tomorrow.
The subwoofer design calls for something like 7-10 cubic feet, using a Dayton RSS390HF 15" driver. It's a vented enclosure with a 6" flared port. I left my students to figure out the exact volume and tuning they want, but with a 24" diameter tube it should end up between 28-36" long. The choice of 24" tube as opposed to a narrower, longer one was an aesthetic decision on their part. (An 18" diameter tube would have to be 4-5 feet long.)
Thanks in advance for any advice!
Michael
Old 2nd August 2008, 08:25 PM   #4
Here's an update: I gave up on trying to find a shorter piece of tube (believe me, I tried). It seems there isn't a market for it; indeed, you don't see many 24" concrete pillars. Although, the guy I bought the tube from explained that they are frequently used in parking lots and below ground.
I bought the 12-foot tube for $135 from Pirolli's in Watertown. There's about 9 feet left. If anyone would like to buy a piece at a proportionally lower price, please contact me!
Old 8th August 2008, 02:23 AM   #5
zobsky is offline zobsky  India
zobsky's Avatar
Go look for a construction supply place . I bought 4 ft long x 18 " wide (they cut to length) from a whitecap store in Dallas, Tx . They had several sizes in stock.
No whitecap stores in your area but you should have better luck pursuing this line of inquiry.
"Any fool can know. The point is to understand" - Albert Einstein
Old 13th August 2008, 03:57 AM   #6
jbell is offline jbell  United States
sonotube is found at concrete construction companies in 12' sections, at every 2" in diameter. (10,12,14,16,18)
just look local yellow pages under concrete construction. (around me it's carter waters)
Old 13th August 2008, 02:25 PM   #7
kevinkr's Avatar
Dead issue guys.. Did you notice that the original poster found and purchased the required sonotube some weeks ago?
www.kta-hifi.net
Old 14th August 2008, 12:29 AM   #8
Right... I appreciate the encouragement though.
The subwoofer came together after last Sunday's class. Looks like it will be pretty impressive, albeit ugly.
Old 14th August 2008, 03:20 AM   #9
Why ugly? sew a 'sock' of grill cloth and wrap it. If you use cloth with just a little stretch, it works great. Then put your top and baffle on, sandwiching the fabric.
Mine always come out looking nice. This top is made out of 2x12 (2 pieces glued together, and then turned down on a table saw) and it still looks good.
FREE - 2ft dia 6ft long Sonotube - Boston Area dhenryp Swap Meet 0 9th February 2009 02:01 PM
Boston Accoustics A60 fwh Multi-Way 6 19th January 2009 03:16 PM
Boston A60's MahangoeMan Multi-Way 1 30th September 2005 06:46 PM
Greetings from Boston AndyN Introductions 3 11th October 2003 10:39 AM
Hello from Boston Won Introductions 0 30th November 2001 01:51 AM
Page generated in 0.14870 seconds (55.11% PHP - 44.89% MySQL) with 11 queries
