#101 | |
Banned
To really understand the details in Thiele or Small's papers requires understanding of engineering circuit analysis and the dynamics of mechanical and acoustical systems. To say otherwise is just displaying your ignorance. |
#102 |
huh?? Thiele & Small correlated measurable electrical and mechanical driver parameters into a basis for predicting loudspeaker behaviour......
What an oddity this has become....... |
#103 | |
Banned
#104 |
Hi
The sub as tested Did Not use the servo feedback loop to reduce distortion. The one he tested used the Linkwitz Transform circuit only. Quote from the Rythmic web site "The kit consists of a 370w amp (A370 SE) with a Linkwitz transform circuit a board, and a DS12 driver without servo feedback. With the Linkwitz Transform circuit we can get a better bass extension than what natural physics gives us. " The LT circuit places great demands on excursion and amplifier power (ie potentially higher IMD) and trading this for a limited amount of frequency extension. Besides it's normal for marketing to make broad sweeping statements or puffery of their products. You cannot use these statements in a technical argument unless lawyers are involved. Cease fire now folks, hahaha.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#105 |
I was under the impression, having read the ht shack bit, that the sub was one using the servo feedback. Rhythmik offers both, and I would have thought that would have been made clear in the review. In fact, the tester makes the claim that the servo does appear to be working, so again, I must assume it was a servo unit.
I still stand by that the claims made my Rhythmik are perfectly acceptable given that they dont ever state the conditions for which it must be true. They do sell a subwoofer, in fact, more than one subwoofer which I would wager can do what they claim. It just so happens that the single 12" subwoofer with servo, in a sealed enclosure, under these particular test conditions (completely free air-no loading) could not meet the claims. However, as has been mentioned, they don't make this claim as something that must be met free air. The claim is less specific, so if, for instance, they were to be sued for false advertising, they could easily argue that the claim was meant to include in room loading. As I've mentioned numerous times, I don't care what type of technology you use, a normal vented or sealed enclosure with a 12" woofer can not easily achieve 100db's at 20hz, in free air, with low distortion without a lot of amplifier power. This also means that the speaker must be capable of huge amounts of linear cone travel, and have huge thermal limits. A servo can help make a cones travel more linear, but I would argue that, in a real room, there are better ways to achieve it. As Zaph mentions in one of his writeups, low excursion woofers have less distortion than long excursion woofers. This of course means, used within their linear range, but still, if you need more linear range, just use more woofers. If you did have a ported enclosure, that would change things some. At the port tuning, 20hz in the case of this argument, the cone would be at minimal motion, and thus, minimal distortion. This is actually seen very easily in the distortion graphs on the HT Shack website, as the ported units generally have a notch in the distortion around the same area as the tuning frequency. This is how my subwoofer achieves this claim. I special version of the TC 3000 subwoofer in a 5 cubic foot enclosure tuned to around 20-21hz. In my particular enclosure it only requires roughly 75 watts to achieve 100db's at 20hz, but if I seal the enclosure, that number increases by close to ten fold. As I recall I measured over 50 volts when I ran some tests a while back, at the time trying to show the efficiency difference of a ported system at low frequencies. This Rhythmik sub, which I believe at least used to have its drivers made for them by TC Sounds, would be in a similar boat. However, as I recall, they were based on the TC2000 not 3000, and would have been of the more typical small box parameters, and thus more limited. oh and there is nothing unmusical about a ported subwoofer tuned to 20hz. In car audio competitions you tune to the cars resonant frequency, typically between 50 and 70hz. This makes for a peaky response, which is what you are referring to, but is quite different from a subwoofer tuned to 20 hz. The Bandpass designs only take this further by tuning to a very narrow point, especially the 6th and 8th order designs, which allow roughly 6-10 db's of gain at that point, but very sharp fall off on either side. That is nonmusical. |
#106 | |
I missed the part where the tester claims about the servo working, besides how would he know unless he disconnected it or compared it to a similar setup without it. Regards,
#107 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#108 | |
I still think you are incorrect. What I see him talking about is the dampening and extension switches, which are a feature of the servo system, not the LT. I believe this was a servo sub tested, not an LT. However, your main point about the LT is still true of the servo. When it comes right down to it, a servo is nothing more than an active "smart" LT. |
#109 | |
I still think you are incorrect. What I see him talking about is the dampening and extension switches, which are a feature of the servo system, and the LT. I believe this was a servo sub tested, not an LT. However, your main point about the LT is still true of the servo. When it comes right down to it, a servo is nothing more than an active "smart" LT. |
#110 | |
Wow I really cannot believe this, now you want to argue with me. Some peoples kids.... just can't let it go. Now I remember why I took 6 mo. away from this forum.
| Rythmik Audio's A370SE Subwoofer modules for sale | mikelm | Swap Meet | 0 | 12th June 2008 12:18 AM |
| Another Rythmik Audio DS12 Subwoofer | jasonlky | Subwoofers | 1 | 2nd February 2008 02:50 PM |
| The Rythmik Audio Rubik's Cube Subwoofer... | Xphile11984 | Subwoofers | 11 | 14th October 2007 10:54 AM |
| FS: NEW Rythmik Audio, A370-SE 24dB Subwoofer Plate Amp $200 with FREE SHIP! | chanorama | Swap Meet | 4 | 10th April 2007 08:22 PM |
| Page generated in 0.13320 seconds (84.16% PHP - 15.84% MySQL) with 10 queries |
