Old 19th July 2008, 05:54 PM   #1
Default Subwoofer Crossover - please critique
Please tell me what you think of this design and how it could be improved.
The basic concept is a L+R mixer, normal / reversed phase selection, 12dB/octave crossover with selectable crossover points, and an output buffer to drive a single cable to a powered subwoofer. The subwoofer will have a Linkwitz transform circuit tuned for the driver and box plus a power amp.
pdf of the LTspice circuit , jpeg of simulation result
pdf of Eagle schematic
pdf of Eagle pcb layout (preliminary)
Credit where it is due: This is all an adaptation of various circuits and ideas from Rod Elliot's ESP website, where I have learned many things. Thanks Rod!
Old 19th July 2008, 05:59 PM   #2
Eagle schem
Old 19th July 2008, 06:02 PM   #3
Eagle PCB
Old 19th July 2008, 06:22 PM   #4
filter response
Old 20th July 2008, 04:44 AM   #5
gregorx is offline gregorx  United States
Why does the output attenuation change with frequency selection?
Language is a virus - William S. Burroughs
Old 20th July 2008, 05:16 PM   #6
It's the same curve, just translated 10Hz with each step. LTspice file attached if you want to experiment.
Old 20th July 2008, 10:11 PM   #7
TL072.sub not found.
The amplitude of the curve appears to change also with the frequency unless I am just completely seeing something incorrectly.
Old 21st July 2008, 12:45 AM   #8
Default TL072 model
from the TI website:
* TL072 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT
* CREATED USING PARTS RELEASE 4.01 ON 06/16/89 AT 13:08
* (REV N/A) SUPPLY VOLTAGE: +/-15V
* CONNECTIONS: NON-INVERTING INPUT
* | INVERTING INPUT
* | | POSITIVE POWER SUPPLY
* | | | NEGATIVE POWER SUPPLY
* | | | | OUTPUT
.SUBCKT TL072 1 2 3 4 5
C1 11 12 3.498E-12
C2 6 7 15.00E-12
DC 5 53 DX
DE 54 5 DX
DLP 90 91 DX
DLN 92 90 DX
DP 4 3 DX
EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5
FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.715E6 -5E6 5E6 5E6 -5E6
GA 6 0 11 12 282.8E-6
GCM 0 6 10 99 8.942E-9
ISS 3 10 DC 195.0E-6
HLIM 90 0 VLIM 1K
J1 11 2 10 JX
J2 12 1 10 JX
R2 6 9 100.0E3
RD1 4 11 3.536E3
RD2 4 12 3.536E3
RO1 8 5 150
RO2 7 99 150
RP 3 4 2.143E3
RSS 10 99 1.026E6
VB 9 0 DC 0
VC 3 53 DC 2.200
VE 54 4 DC 2.200
VLIM 7 8 DC 0
VLP 91 0 DC 25
VLN 0 92 DC 25
.MODEL DX D(IS=800.0E-18)
.MODEL JX PJF(IS=15.00E-12 BETA=270.1E-6 VTO=-1)
.ENDS
Old 21st July 2008, 01:41 AM   #9
Ok I got it to run. I was confused previously by the stepped attenuation in your simulation. I turned those off for a second (but I am going to copy them for my own simulations soon) and made the attached graph.
I like how fast the high end rolls off but assuming I did the simulation correctly --big assumption-- it appears that the low end rolls off too quickly.
Old 21st July 2008, 02:13 AM   #10
There's two sets of spice directives - one for the AC simulation which steps the resistor values to change the crossover point, and one to step through the gain values for a time domain simulation. I toggle them between comment and spice directive depending on which one I want to run.
Delete the two 0.22u caps on the input to get rid of the low end rolloff.
subwoofer with no crossover MikeN Subwoofers 9 2nd December 2008 07:17 PM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
Subwoofer Crossover Dj BASS AMP Solid State 7 30th December 2005 04:46 PM
$2 speaker, $10 crossover (Can somebody critique my design?) Jim85IROC Multi-Way 9 10th March 2004 05:03 PM
Subwoofer Crossover amoeba86 Subwoofers 1 17th May 2003 01:53 AM
Page generated in 0.14177 seconds (64.85% PHP - 35.15% MySQL) with 11 queries
